11-28-2018, 04:49 PM | #1 |
Rep 6
What Milage did you change ZF Transmission Gearbox oil fluid
Hi - I’m new to the forum I’ve owned a E90 320d manual for 2 years and now got a 2013 F30 335d Xdrive - it has done 85500 miles which includes 2500 that I’ve put on myself - keep seeing a lot about getting the fluid flushed out and and genuine service/oil and filter kit being done at either 62k or 8 years - the car as been looked after and as high milage for its age (taking that is a good point) but was thinking getting it done for £400 at a transmission specialist - does anyone think it’s the right time, as it been long overdue or could you take it further
11-29-2018, 08:56 AM | #3 |
1324
Rep 1,642
This is something I was ambivalent about until recently. Then, someone posted on here that they had over 150k on their original fluid and that the transmission was running fine. More recently, there was another post where someone changed it around 60 or 80k and the fluid looked fine and the transmission pan had very little metal residue on it. With that info in hand, I have decided to not change the fluid at all. If you search recent threads on this topic, you will come across the posts I mentioned.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
11-29-2018, 05:05 PM | #5 | |
809
Rep 1,910
Good Luck/Bill |
Polo088161614.50 |
11-29-2018, 06:37 PM | #6 |
1324
Rep 1,642
True, but I think it is worthless the other way around - i.e. darkened fluid doesn't necessarily mean it is bad. OTOH, if the fluid looks like it has hardly changed color from new...seems to me that that tells you something about the fluid. But yes, I agree that a full lab analysis would be much more worthwhile. I just haven't seen a lab analysis anywhere of the ATF fluid for our cars.
11-29-2018, 07:28 PM | #7 |
967
Rep 2,655
Did mine at 57K with the FCP Euro kit. Trans loves the new fluid and shifts are smoooth. My lab analysis of transmission fluid...
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
11-29-2018, 09:20 PM | #9 | |
245
Rep 2,387
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
11-30-2018, 05:09 AM | #10 |
714
Rep 1,329
Given my personal experience with previous high mileage BMWs and a few ZF transmissions in other makes, the old oil does start to not look good at about 80k or 8 years - depending on use, and I have noticed physical effects on the transmission between 85k and 110k miles - 7 to 9 years, so I am in the camp that I would not go past maybe 65 to 75k depending on conditions.
If you don't plan to keep the car that long, you can just say it's the next guy's problem, but even if I were planning to sell before 75k I would still spend to swap out the fluid at least, save the planet and all. Really environment and driving habits do effect it as well. If it is mostly long distance highway use in a temperate climate, you can certainly go longer. I have quite mixed driving and hot and cold climate extremes, so mine is probably rougher than average on the fluids. I am not super insane on fluid maintenance, but engine oil, trans fluid and coolant are the three I don't cut corners on. Not the frequency or quality of parts and fluid.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
eksigned139.00 |
11-30-2018, 06:38 AM | #11 |
2467
Rep 5,457
Drives: F30
Im currently at 64k and plan to replace pan and fluid around 70k.
Still debating on paying the dealer $700 or spending $400 myself and having the stress of the DIY to worry about. Anyone else get a dealer quote ? |
11-30-2018, 07:24 AM | #13 |
2467
Rep 5,457
Drives: F30
11-30-2018, 07:59 AM | #14 |
245
Rep 2,387
It's not a bad diy. If you have an xdrive you'll likely have to drop the front drive shaft. Other then that, no biggie. And get a laser thermometer as the fill is temperature dependent.
sspade2467.00 |
11-30-2018, 09:14 AM | #15 | |
1324
Rep 1,642
While I am very proactive about all my car's maintenance care, I do not see myself keeping it beyond 2022/130k miles and therefore do not plan to drop a grand on this service. I really do not believe the transmission will fail before then or even soon after based on the way it is behaving right now (84k miles). So for my personal situation, I am at peace with this decision. May turn out to be a mistake, but then at least I can contribute a datapoint to this forum saying that my transmission failed because I did not change the fluid for 130k miles.
11-30-2018, 09:15 AM | #16 |
1324
Rep 1,642
Seems like the oil is holding up well!
11-30-2018, 09:21 AM | #17 |
1615
Rep 3,953
It is interesting that part of the procedure has you overfill the transmission by 0.5L.
11-30-2018, 09:41 AM | #18 |
1599
Rep 3,748
Why can't they just design a more conventional ZF transmission where you can just drain them through a drain hole....then just and fluid. Why is the oil pan need replacing why why why it just hold the oil
11-30-2018, 09:44 AM | #19 |
967
Rep 2,655
It seems so. Hope it stays that way
11-30-2018, 09:44 AM | #20 |
809
Rep 1,910
...German Engineering 😉. The fluid's filter is integral to the plastic pan assembly.
11-30-2018, 11:12 AM | #21 |
2467
Rep 5,457
Drives: F30
Anyone close to 95624...
who wants to do this together, PM me. I have a garage and tools. BimmerLink also has two different trans temp readings available to us. I believe one other member is interested as well. |
adhrp1324.00 |
11-30-2018, 01:45 PM | #22 |
2001
Rep 2,499
ZF recommends a 62k mile (100k km) change interval for the ATF. I'd go with the company that created the transmission as the best recommendation. They recommend a maximum of 8 years in between ATF changes. The process is easy enough for a home mechanic to do and cheap enough for a good indy shop to do.
A transmission fluid flush is cheap insurance. If you're the type that doesn't really care about how their car runs, sure let it go to 150k miles. It'll "work" but it won't be optimal. Spend a couple hundred bucks and keep your transmission running well. The ZF 8HP has very tight tolerances and letting the transmission fluid go too long could negatively affect its performance. What makes the 8HP such a good transmission is that it feels so fast and precise when it shifts. You will lose that if you let old fluid stay in there for so long. |
metallicpea714.00 |
