BMW X5
      11-26-2018, 04:43 AM   #1
Minnie
39
Drives: 2019 X5 40i M-Sport; X3
M Sport Brakes?
I have a week 49 build, next week, so I guess this is the latest I can make changes.
I'm considering adding M-Sport Brakes.
What's the difference to normal brakes, when do sport brakes make sense, or is it just a cosmetic option?
Thanks!
      11-26-2018, 06:14 AM   #2
lumpydog
lumpydog's Avatar
691
Drives: 2019 X5
You will likely shift over to production as early as this morning, so if you want to make any changes, I’d call you CA first thing this morning...
I’ve read that M brakes may make sense when using larger rims for a few reasons:
1) I’ve read here that larger rims need more brake force (not sure if that’s true) - M brakes use larger calipers/pads.
2) You can clearly see the calipers with the larger rims and the stock ones aren’t that impressive.
I’m going with 19 inch rims and stock brakes... primarily because I prefer the less-harsh ride and I live in the Northeast, where potholes destroy large rims.
Minnie38.50
      11-26-2018, 07:09 AM   #3
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
They are bigger better calipers, but honestly I bought them for cosmetic reasons (especially after looking at the rusty crap on my F15).
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
Appreciate 2
Minnie38.50
beattiecj127.50
      11-26-2018, 07:32 AM   #4
Minnie
39
Thank you both for your answers.
I will try to add those, hopefully my CA works today.
Better brakes can't hurt and I like the optics.
Thanks.
      11-26-2018, 02:56 PM   #5
BGT3
44
Drives: M550ix
Don't think the disc material is any different so the rust issue will be the same which happens to all iron based discs when the car sits in the rain or after a wash. Comes right off anyway the 1st. time you touch the brakes. If your calipers are rusting that's a different issue and should be replaced under warranty.
The only exception is carbon ceramic brake discs which are not available and extremely expensive.
2018 M550ix
2019 X5 M Sport 40i
Porsche 997 GT3
Porsche 993 C2 Cab.
      11-26-2018, 02:59 PM   #6
roadkillrob
Ya the discs I am sure will rust - I usually paint them as soon as I get any car (they used to coat the hubs years ago but not anymore. My issue is the brake calipers are rusty and look like crap also on my F15.
2008 E93 335i FBO
      11-26-2018, 03:43 PM   #7
qwerty_01
Drives: BMW X5
I asked similar question before but nobody seems knows the exact answer.
A lot of people said M sports use larger caliper and pads (including in this post) but there is no evidence to prove that. I really keen to know how many pistons on standard brake (front and rear) and M sports brake (front and rear)? At the mean time I would also like to know what is the diameter of brake pads on standard brake and M sports brake.
The price to option M sports brake is only few hundred dollars so I guess there is no big difference between standard brake and M sports brake in performance.
      11-26-2018, 08:40 PM   #8
roadkillrob
The description says large discs and different pads - caliper is likely the same just painted nicer. Large discs could mean larger but may not - if it is like X3, the standard rotor is 330mm and the m-sport rotors are 348mm.
2008 E93 335i FBO
      11-26-2018, 08:59 PM   #9
X54TH
Member
X54TH's Avatar
898
Drives: 2019 X5 40i M Sport
What's the brake dust like on G05 with m brakes? We get zero brake dust on our current F15 which was great. We have a 2016 m235 and that's a weekly clean up. I hope the G05 is not the same.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
      11-26-2018, 09:12 PM   #10
Buckett76
47
Drives: 2019 BMW X5 xdrive40i
Definitely bigger but can't say exact measurement. Here are the MSport front disc and calipers and the regular with the same 20" wheels.
Appreciate 5
Minnie38.50
1230vani650.00
sahajesh2294.00
cptcolo102.00
      11-27-2018, 06:34 AM   #11
roadkillrob
Yep that is definitely bigger - I believe both calipers are 4 piston, but the msport one is certainly bigger and piston outlines look to be larger pistons also which would indicate larger pads also.
2008 E93 335i FBO
Minnie38.50
      02-28-2019, 04:25 PM   #12
QVDriver
22
Drives: X5 50i Alfa QV MINI
I will have to look at them at the dealership when I go in there Saturday. We have the 22" wheels on the 19 X5 50i and the calipers look huge but they are not sport brakes at least they are not blue. I will compare when I see them. I would like to have mine powder coated but if the calipers are all together different than I won't. I am just thinking for a $650 build upcharge it can't be a whole lot of difference between the two and maybe it is the powder coating that they are upcharging for.
I do have a Alfa QV with Carbon Ceramic brakes. There is no brake dust with CCMs but yes they are costly but nice and also costly to replace but not for a long time. I can't see a reason to have CCMs on an SUV. Heck unless you are tracking you don't NEED them but they sure do fill that hole quite nicely on the sedan.
2019 X5 50i CARBON BLACK M PACK
2017 ALFA ROMEO GUILIA QV
2013 MINI COOPER
      03-02-2019, 12:30 AM   #13
mbarrett635
Drives: 2019 X5 40i
The front rotors are larger with MSport brakes -- 395x36 vs 348x30 (or 348x36 for vehicles with 3rd Row Seating). Brake pads have a larger area. The rear brakes are the same on all vehicles (but are matching blue for MSport).
      03-02-2019, 09:57 AM   #14
rmorin1249
rmorin1249's Avatar
817
Drives: 2019 X5 MSport 40i
The M pads are larger and a different compound. They also tend to be more dusty.
COL(Ret), US Army Hagerstown MD
2019 X5 40i MSport Alpine White/Coffee (my 13th BMW)
2015 Mercedes SL400; 2009 Lexus RX350
      03-02-2019, 11:16 AM   #15
bigrobb2
bigrobb2's Avatar
Drives: 2019 X5 40i
I almost went with the standard package. Happy I changed my build last minute. Bigger brakes look better with the 21 inch rims. Brake dust is still better than standard Bmw brakes from years ago.
      03-02-2019, 02:25 PM   #16
mbarrett635
Drives: 2019 X5 40i
It's hard to compare dust levels since I don't have both side by side, but the dust levels with my MSport brakes are not all that bad, in my opinion (they don't make noise, either). Certainly much better than the black dusty brakes from earlier BMWs.
      03-02-2019, 05:04 PM   #17
rmorin1249
rmorin1249's Avatar
817
Good to know. I know they have greatly reduced the dust over older models. I had a Z4 that I could literally drive around the block and the wheels would be coated with dust. My F10 was much better with far less dust.
      03-03-2019, 10:03 AM   #18
Abegweit
29
Drives: 17' 340 6mt/19' X5 40i
There are actually 3 different brake setups available for the G05. 40i without 3rd row gets the basic spec, add 3rd row and/or 50i gets first upgrade, M Sport gets M upgrade. Full details are in the technical training documents pinned in this forum. No speculation required.
      03-03-2019, 11:02 AM   #19
AndroidRobot
AndroidRobot's Avatar
Drives: 2022 Porsche Boxster GTS
  [0.00]
2022 Porsche Boxste ...  [0.00]
50i M Sport brakes don't make a huge amount of dust and they're massive. I wish we had ported brake discs but either way they work well
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order)
2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD)
2018 BMW M2 Mineral Grey(SOLD)
2019 BMW X5 50i Carbon Black/Tartufo (SOLD)
      03-03-2019, 03:45 PM   #20
Denk
Denk's Avatar
1006
Drives: 2021 X5M
M Sport brakes bite a little harder, less pedal pressure to get the job done. The standard brakes have a softer pedal pressure, more pedal travel. The M Sport brakes are still a little soft to me, I just need to get calibrated to them.
      03-03-2019, 04:45 PM   #21
Tlon
173
Drives: 2019 X5
Same here.
I do find the MSport brakes to be a tad touchier than the non-MSports I've had on previous G05s (so not comparing apples to apples, I know). That is, they grip faster, so stopping can be less smooth. And they seem to let go quicker, so starting can be a bit jerkier when you're trying to smoothly inch out. At least, that's been my experience. Not all the time, so it could be a touch issue.
No noise but I bedded them immediately, and I see no brake dust but I did get ceramic coating on the wheels and the 740M wheels have enough gray, which may help.
      03-03-2019, 06:02 PM   #22
AndroidRobot
  [0.00]
Same here.
I have ceramic coating on my wheels too so maybe that's why I noticed nearly no dust, there's some just a very small amount.
xbimmers
