2010 2011 BMW 5 Series Forum F10 Does this car actually have DHP? |
11-25-2018, 01:07 AM | #1 |
66
Rep 241
Hey guys,
Searching for an F10 to buy with DHP. This seller says it has DHP but when I put the VIN into the decoder it only has adaptive drive, but not dynamic drive or dynamic damper control. I can't tell if the vin decoder is wrong or if their window sticker is wrong or I am misunderstanding... https://www.nyautogallery.com/used/B...817bab2794.htm https://www.mdecoder.com/decode/du73354 |
11-25-2018, 03:26 AM | #3 | |
6659
Rep 15,858
11-25-2018, 10:44 AM | #4 | ||
60
Rep 214
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, SAT, Driver Assistance Pkg, Premium Pkg, Multi-Contour Heated Seats, Navigation, H/K stereo. Michelin Pilot Sport 4S non-runflats, M5 grille, Painted reflectors from IND.
11-25-2018, 10:48 AM | #5 |
327
Rep 697
Drives: 2013 535xi
In this rare instance, you are mistaken. My xDrive has dynamic dampers and active role stabilization. I ordered it this way from the factory. OP, just in case you didn't already know this, on non-xDrives, the 704 sport suspension was available, but it does not constitute the DHP but rather a static, sport-tuned suspension.
2013 535xi, Carbon Black, beige interior, M Sport package, HUD, DDC & ARS, ACS springs, Kelleners wheels
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
Kyngofpop676.00 |
11-25-2018, 12:18 PM | #6 |
66
Rep 241
I thought so too, but when I look at another example it lists more options in the VIN decoder: https://www.mdecoder.com/decode/du58758
For example, this vin decoder lists dynamic drive and dynamic dampers, while the original vin decoder I listed only lists 2VA. The fact they are different has me worried.. |
11-25-2018, 01:29 PM | #7 | |
6659
Rep 15,858
Kyngofpop676.00 |
11-25-2018, 02:15 PM | #8 |
66
Rep 241
11-25-2018, 02:40 PM | #9 | |
4442
Rep 7,485
BMW is known for making changes during the production run. An option could be offered as a stand-alone at one point, then gets incorporated into a package later...or could be not offered as a stand-alone but only available as a package. For example, the SVA package includes multiple options that may have been stand alone on earlier versions. If you do a search for the 2010, 2011, 2012, 2013 BMW F10 pricing and ordering guide PDFs it may reveal the mystery or confusion you're running across.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
danperson165.50 |
11-25-2018, 05:10 PM | #10 | |
66
Rep 241
11-26-2018, 09:20 AM | #11 |
4442
Rep 7,485
FYI: just as suspected...looks like BMW changed the bundling nomenclature of the DHP (dynamic handling package).
On early ordering & pricing guides...DHP nomenclature and bundled option codes are: ZJY - Dynamic Handling PackageThen later the DHP nomenclature & bundling changed to: ZDH - Dynamic Handling Package
danperson165.50 Kyngofpop676.00 |
11-26-2018, 10:05 AM | #12 | |
66
Rep 241
12-11-2018, 11:27 AM | #13 |
388
Rep 951
Any chance you can get under the car, you will be able to figure this out very quickly. Look for wires coming out of the bottom of the shocks/a little module arrached to the bottom of the shocks, and if you try to peek through the under cover while looking at the sway bar, you’ll see a big cylinder in almost the middle of the sway bar again with a wire/harness going to it. If you have those two things, you have BMWs best suspension(according to them).
danperson165.50 |
