11-22-2018, 10:02 PM | #1 |
The limit of adhesion is my home.
1702
Rep 3,778
Adaptive Mode: Anyone using it a lot?
If you ordered it - the X3 comes with the additional "adaptive" setting next to the 3 regular settings we usually have (sport, comfort, eco). I'm just so used to selecting "sport" or "comfort" and figured this additional mode may prove a good addition to the driving dynamics of the car.
I was wondering if anyone here uses it a lot and does it really work well? I saw a video of it, explaining how it is supposed to work but wanted to hear some real-world thoughts on it. (I know that's a 5 series but couldn't find a video about it on the X3...I'm assuming its the exact same system)
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
11-22-2018, 11:48 PM | #3 |
16
Rep 100
I use it a lot, and consider it to be Comfort mode for most of the time, but when you floor the gas it feels like it moves a lot quicker and makes a lot more noise
11-23-2018, 01:17 AM | #4 |
783
Rep 911
Drives: 2020 X3 M40i
Like frank23 says, like Comfort, but will "Sport up" quickly and stay like that as long as you're driving spiritedly.. then fail back to Comfort. Basically, an aggressive Comfort mode.
11-23-2018, 01:50 AM | #5 |
1702
Rep 3,778
Interesting....That's actually really cool if it worked that way. In the video it says that it also guided by GPSs and road maps. So maybe on "curvy roads" or freeways it changes as well. I guess if you select adaptive mode, its a great way to also not to have to think of switching modes on the fly.
11-23-2018, 02:22 AM | #7 |
74
Rep 433
Not sure about the X3 but my 6 had it and it added comfort plus which was softer than comfort and ok for the road where I live, howerver on a motorway comfort plus was too soft and it felt like an old merc I had, a bit like being on a boat and a bit floaty so I would always flick to comfort for motor way driving.
In the UK when you order a 40i or 40 d and pick the msport plus pack it comes inclusive so you can t get rid of it to save some cash and use it on another option. From memory I think it was best part of £1k on a 3 series....
David - Bored with Audi
MY2019 X3 40D M-sport with all the toys. Also a Mini CS for the wife and me to play in at the weekends |
11-23-2018, 07:00 AM | #8 |
259
Rep 453
I use adaptive most of the time, I prefer the sport mode but between the switch not working properly and the neighbors getting an ear-full of the pops and burbbles i just use adaptive.
11-23-2018, 09:09 AM | #10 |
176
Rep 1,063
What was this packaged with in the US -- the M Adaptive suspension? I have everything except for that, and I don't have the "adaptive" mode -- just Sport, Comfort, and Eco Pro.
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
11-23-2018, 09:26 AM | #11 |
129
Rep 276
11-23-2018, 09:51 AM | #12 |
4332
Rep 6,121
Drives: 2022 Porsche Boxster GTS
I either drive in Adaptive or Sport+ so yes I use it quite frequently.
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
11-23-2018, 10:33 AM | #13 | |
494
Rep 1,044
New England weather rots out suspensions no matter how clean you keep the underbody. So for both my MY18 30i and MY19 M40i, I passed on this option. In five or so years, I'll have to a lot to replace shocks and bushings but at least I won't have to pay to replace the even more expensive electronic shocks that come with adaptive suspensions. Hopefully, there will be good aftermarket products for the 30i at least and maybe even the M40i.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
11-23-2018, 10:34 AM | #14 |
66
Rep 120
I had Almaretto code mine to default to Adaptive on start-up, so I use it almost all the time. The differences between Comfort and Sport steering/suspension feel pretty subtle, but I assume when I take corners at speed it's switching over to Sport for the curve. I hadn't seen this mode advertised as employing other Sport settings but from a couple of comments above, it sounds like it's also using Sport transmission mode at least, which makes sense - my car hangs at 5k rpm in Adaptive longer than I'd expect when I give it major throttle on the highway.
11-23-2018, 11:58 AM | #15 |
448
Rep 525
I agree on that but it doesn't change the suspension settings which makes the car handle dramatically better if in sports mode.
11-23-2018, 02:41 PM | #16 |
66
Rep 120
Part of my point above was that even switching manually between comfort and sport, the suspension change is subtle. Adaptive (as included with Dynamic Dampers, which is included in the Dynamic Handing Package) is marketed as effectively pushing the Comfort and Sport buttons for you based on various criteria. What makes you think Adaptive does or would do something different?
11-23-2018, 03:42 PM | #17 | |
448
Rep 525
11-23-2018, 04:02 PM | #18 |
66
Rep 120
That’s good to know. They must have tuned the dynamic dampers with a much narrower range in the 30i to align with the target market. Lower profile tires on the 40i may reveal more as well. Still would be good to get a definitive rundown on what adaptive is doing across all drivetrain and chassis parameters between both models when so optioned, and at which condition thresholds.
11-23-2018, 04:54 PM | #19 | |
4332
Rep 6,121
11-23-2018, 06:06 PM | #20 | |
382
Rep 1,054
11-23-2018, 06:29 PM | #21 | ||
4332
Rep 6,121
11-23-2018, 06:34 PM | #22 | |
Head Idiot
251
Rep 551
I'm now using Sport Individual (everything sport but comfort suspension). and it's a lot nicer. Sucks to lose ASS, but I can hit eco while sitting in a drive-through line. |
Fenders66.00 jjrandorin355.50 |
