11-20-2018, 10:32 AM | #1 |
551
Rep 980
Harman Kardon improving...
For those with HK audio...
I've been tolerating highish volume levels most times when I'm out in the car and it's already starting to sound better around the bass end. It sounds like the mid/low drivers are relaxing a tad, which has required me to reduce a couple of the low-frequency levels on the eq. It's not a bad system for the money! I think I'll turn the volume down a bit now - give mi Donalds rest! |
11-20-2018, 10:55 AM | #2 |
80
Rep 239
Still lacks the rolling and thumping bass in my opinion. I've got a Harmon Kardon in my other vehicles and sounds amazing, like my 2018 Hellcat... Something about European cars that lacks in the stereo department... Never had a good system in a Euro car.
11-20-2018, 10:55 AM | #3 | |
The limit of adhesion is my home.
1702
Rep 3,778
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
11-20-2018, 06:45 PM | #4 |
1910
Rep 5,105
Having made adjustments to the EQ, mine is awesome. Much improved over previous HK systems I've had in other bmws
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
11-20-2018, 07:06 PM | #5 |
551
Rep 980
I agree. Also as a bass guitarist and consequently being a bit of a audiophile I do appreciate clear and dynamic systems. Most cars lack in the factory fitted systems they have, but, for the money, some are fairly good. I reckon one of the best factory fitted systems in a European car is the ‘top option’ system in the Audi A8 - it’s pretty good!
Neo113080.00 |
11-20-2018, 08:41 PM | #7 |
80
Rep 239
I turn the treble and bass all the way up and the mid range down one or two ticks. It isn't the best setting for the loudest listening but it sounds good IMO at mid range volumes... Thing is, not everyone will have the same setting. People vary in the ranges that they can hear the best at so it's all personal preference. I wouldn't base your system on someone else's range of hearing.
After constant jet engine and gun fire I was exposed to in the military, I have to listen to my music fairly loud. Good thing the rest of the family loves loud music. LOL |
11-20-2018, 08:57 PM | #8 | |
132
Rep 232
Where are the audiophiles eq settings? |
11-20-2018, 09:07 PM | #9 | |
1702
Rep 3,778
Try these as a baseline and see how it sounds: Logic 7 - OFF Treb +2 Bass +2 Balance 1 to the right Fader 1 to the left 100HZ +2 200HZ +1 500HZ +2 1KHZ +3 2 KHZ -1 5KHZ +1 10KHZ -2 Hope that helps some. EQ adjustments should really only be minor.
IXVXI131.50 jjrandorin355.50 |
11-20-2018, 09:29 PM | #10 | ||
1006
Rep 1,727
11-20-2018, 09:45 PM | #11 |
1702
Rep 3,778
I've found central imaging to be way more "whole sounding". Logic 7 does give you the "surround feel" but at the expense of it NOT sounding like they are performing right in front of you. I definitely prefer the latter. Also - when you crank up the volume, the sound is cleaner when Logic 7 is off.
and I also did EDIT the above settings and added an adjustment for balance and fader - You asking me reminded me of this setting as well - depending on how often you ride alone in the car....it sets the imaging to be more "directly focused on the driver", as well as a small compensation to turning the Logic 7 off and providing a tad more "surround" feel by placing a little imaging behind the front seats.
11-20-2018, 10:22 PM | #12 |
132
Rep 232
SROC3 isn't your X3 still in production? If so how do you know these settings are good?
11-20-2018, 10:29 PM | #13 | |
1702
Rep 3,778
Note - that I also mentioned in an earlier post that when I break-in a new system I just leave the EQ flat and only make minor adjustments on the Treb/Bass. This way when you apply the above settings you will have a more "true" baseline to compare them to. When I do get my ride (which will be arriving Dec. 8th at the dealer), I will for sure create a new thread on my EQ settings after I make adjustments
11-21-2018, 12:34 AM | #15 |
218
Rep 392
I initially never understood reviews asking about the speakers bedring in and loosening up but it seems from multiple reviews that after 100 hours of use this is a real thing and people do notice a difference
11-21-2018, 12:56 AM | #16 |
Rep 4
Thanks. Default from factory to me is... well, underwhelmed would be an understatement. Pretty much my only real gripe about the car.
11-21-2018, 08:36 AM | #17 |
1702
Rep 3,778
Yeah completely agree.....you should try sitting in an X3 with just the regular Hi-Fi system and not the HK. No equalizer and less speakers too. Sounds great right at the get-go. It's just that the volume cannot be turned up as much and the speakers start to distort at 85%.
11-21-2018, 09:05 AM | #18 |
80
Rep 239
I thought the same thing. After about 1,000 miles on our X4, I HAVE noticed a slight improvement in bass response and a little less muffled sounding.
11-21-2018, 07:12 PM | #20 |
144
Rep 252
Curious - at what level do most people find the head unit or mids/highs start to clip/distort?
In my mind it’s the second half of the second “e” in entertainment based on a wireless car play source. I realize there’s no hard science behind what we hear, but curious of other people’s perceptions unless someone has actually measured the point where the HU starts sending a clipped signal? |
11-21-2018, 07:29 PM | #21 | |
80
Rep 239
