11-18-2018, 02:39 AM | #1 |
36
Rep 84
M sports suspension (HAS)
Anyone had this installed? See below...
https://www.parts.bmwgroup.com/infod..._014_02_18.pdf If so, how is the ride quality in comfort mode, still ok? |
11-18-2018, 12:13 PM | #3 |
595
Rep 824
12-07-2018, 11:57 AM | #5 |
///M Driver
223
Rep 268
Drives: 2018 First Edition M5
I would like to know if somebody installed them and what their thoughts are as well!
Currently driving: 2018 M5 First Edition
Vehicles Owned: 2014 M5 ZCP, 2017 M3 ZCP |
12-30-2018, 06:02 PM | #8 | |
599
Rep 556
15mm drop on this, which is conservative, but a nice compromise. Competition is set up -7mm F/-10mm R compared to stock, so I guess would go -12/-15 on this one. |
12-31-2018, 12:43 PM | #9 |
36
Rep 84
Base model.
Decided against the competition when I realized I would be swapping out the suspension, exhaust, wheels, and black trim. If I was gonna leave the car stock I would've gone competition. |
01-02-2019, 03:08 PM | #10 | ||
Plenipotentiary
2614
Rep 3,046
On the std car, the spring rates are a little different, and ride height adjustable from -0mm to -25mm. Comp already has different kinematics, shortened springs (-7mm) with +10% stiffness, shorter aux dampeners (bump stops) and requires different spring rates than what's offered with this specific kit. Although one could technically install this as is on a comp, it's not a good solution. During severe load reversal situations, the spring rates are inappropriate and it bottoms out on the bump stops. |
01-10-2019, 06:47 PM | #11 | |
599
Rep 556
Was interested in a BMW solution. I've installed springs on previous cars and a mismatched spring and damper is not fun. |
01-27-2019, 10:03 AM | #12 |
168
Rep 454
04-24-2019, 09:13 AM | #17 |
Perennial PFC
336
Rep 1,274
04-24-2019, 10:36 AM | #18 | |
4074
Rep 5,233
This is based on my experience with KW HAS so take it for what it's worth. On the flip side, you can adjust endlessly until you find the setup that works best for you.
04-24-2019, 11:49 AM | #19 | |
Perennial PFC
336
Rep 1,274
04-24-2019, 08:05 PM | #21 |
Perennial PFC
336
Rep 1,274
My dealer checked today, one available in the US. Retails at $1,860, plus BMW itemizes about $300 in extra mounting hardware. My guess is that BMW wants to replace every nut and bolt that has a wrench put on it! I doubt it would be that bad, but still pricey compared to KW HAS. I wish someone would be the first to take the jump, KW is a known quantity and usually good.
04-24-2019, 08:59 PM | #22 | |
3322
Rep 8,083
i was hoping i could add it into my fathers car being built as we speak. as a port option i suppose. |
