BMW X5
      11-15-2018, 02:35 PM   #1
heinzena
117
Drives: 340xi M-Sport
Exhaust Hack
If you guys want to modify the sound of your exhaust, without adding MPPK here is how to do it -- I did it on my 340i and it sounds pretty darn good. The system described below appears to be the same on the new X5:
There is a valve on the right exhaust. This is usually closed, until the engine gets above ~4000 rpm, then it opens. This valve is controlled by a servo motor. To see it you'll have to crawl under the right exhaust (don't do this right after driving, its hot!). You'll see a wire plugged into it. Put your car in park, put the car in sport mode and hit the gas hard. This will open the valve. If you shine a flashlight in there, you will see it open (the flap runs parallel to the exhaust pipe). Now, before it gets too hot, get back underneath the right exhaust and unplug the wire from the servo. Now the valve is permanently open. I then wrapped the exposed wire and the socket on the servo (kind of looks like a USB) in plastic and electrical tape to prevent it from getting wet, and taped it too the body so it didn't dangle below. A little ghetto, I know, but it sounds great and cost nothing. Has a nice growl and lots of pretty over-run burbles.
I'm assuming this will work with the X5 as well, as all the same components are there, and I plan on doing it when I receive my week 49 build.
If someone tries this, please post your results!
MPoweRo428.00
      11-15-2018, 03:56 PM   #2
Jrunr
Germany
188
Drives: 2019 BMW X5 M40i - G05
Or if you get yours first, please try it and record the results! That would be awesome.
      11-15-2018, 06:33 PM   #3
proveg
Drives: 19X5
This in theory can be controlled by coding.
      11-16-2018, 04:31 AM   #4
MPoweRo
MPoweRo's Avatar
Australia
428
Drives: F82 M4 ZCP LCI2 M, G05 X5 40i
Great hack! Let us know how you go and I may follow.
M4 Times (PSC2): Sandown: 1.21.76 Winton:
1M Times (PSC2):
Phillip Island: 1.53.09 Sandown: 1.24.03 Calder Park: 1.07.31 Winton: 1.36.71
      11-16-2018, 07:17 AM   #5
denniss
denniss's Avatar
392
Drives: BMW
i dont know, i think its a bit crazy/ghetto to hack $80k truck.
      11-16-2018, 07:34 AM   #6
heinzena
117
I ghetto hacked my $65k 340 Msport the day I got it and haven’t regretted it since.
      11-28-2018, 12:20 PM   #7
ARam
ARam's Avatar
61
Drives: 2016 BMW X5M
The problem with the APP is that the code only work as long you have a constant connection (OBD2 +iPhone APP) for the exhaust to be open. Once you lose connection or turn off your car the flap will automatically to the close position. I tried this on my X5M and after 10 minutes it closes again.
      11-28-2018, 12:22 PM   #8
ARam
ARam's Avatar
61
Will try this when i get my 2019 in Dec.
      12-03-2018, 01:24 PM   #9
denniss
denniss's Avatar
392
Drives: BMW
tried this last night, i had car in sport plus and wife reved the mottor to over 4000rpm and nothing opened.
So unless i am doing this wrong this might not work with X5.
      12-04-2018, 05:16 AM   #10
tobian
Poland
25
Drives: 2019 BMW X5 40i
Any sound of 40i with M sport exhaust?
      12-06-2018, 11:20 PM   #11
Erthomas25
Drives: 2019 BMW X5
Anyone else try this on their new X5 and have success? I would love to increase the sound of my exhaust.
Appreciate 2
      12-21-2018, 08:23 PM   #12
heinzena
117
I haven’t been able to get this to work, as the exhaust pipes are curved and I cannot see the flap, so I don’t know when it is open. I can feel heat on one side and no heat on the other, which would indicate the flap is closed. I’ve tried mashing the gas (which worked in my 340) to open it, but the lack of heat emission leads me to believe the flap remains shut unless the car is moving. So disappointed!
      12-22-2018, 12:34 AM   #13
elitex
elitex's Avatar
Drives: 22 M8C Coupe, 21 X5MC
I've done the same to all of my M cars and our new X5 50i. V8 in the X5 has a nice growl.
Previous
21 X5M MBB, 20 Evora GT, 20 C63S Coupe,19 X5 50i, 18 Giulia QV, 18 M5, 17 Evora 400, 18 LX570, 17 GT350,18 M4 Comp,17 R8 V10 ,17 M3 Comp,17 GT350,16 Escalade Plat ESV, 16 570S,16 911 GTS,15 M5, 15 LX570, 13 M5,13 Viper,14 Cayman S,13 M3,13 S4,10 RX8,12 A4,10 G37, 04 Mini Cooper S, 08 Scion TC, 06 Altima V6, 05 Altima, 01 Altima, 00 Altima, 94 Explorer, 92 Toyota Pickup, 98 Altima
      12-22-2018, 04:12 AM   #14
JLR0523
90
Drives: 2019 X5 50i
Agree. Really like the sound of the 50i m sport exhaust. Enough growl without over the top loud. Perfect for the wife.
      12-22-2018, 08:19 AM   #15
heinzena
117
Can see the actuator and am able to pull the wire, but because the pipe curves, I can’t see when the flap is open, and hitting the gas in sport mode doesn’t seem to do it.
Any ideas anyone?
      12-22-2018, 09:12 AM   #16
salfeet84
Drives: 2024 X7 M60i
How did u do it, plz share details
      12-22-2018, 09:15 AM   #17
elitex
elitex's Avatar
So my X5 50i is an M sport. You can hear the difference when valves are opened vs closed. Can't see them but hear them.
Start the car, put it in sports plus, Rev a bit then shut it off. Uplug the valves after shutting the car off. Simple really.
Previous
      12-22-2018, 12:46 PM   #18
heinzena
117
Is yours a G05?
      12-22-2018, 12:47 PM   #19
elitex
elitex's Avatar
Is yours a G05?
Yes
Previous
      12-22-2018, 01:03 PM   #20
heinzena
117
Yes
Either way, completely different exhaust system and likely different software controlling it. Just wish I could figure out how to get the valve open so I can unplug the wire
      12-22-2018, 01:53 PM   #21
elitex
elitex's Avatar
Yes
I've done this to two different F10 M5's, F90 M5, F82 M4 and F80 M3 and now the G05 X5. It worked every single time. F10, you just had to tie the valves to remain open.
F90, F80 and F82, it was easier since you can see the valves.
Previous
      12-22-2018, 02:11 PM   #22
heinzena
117
I did this on my 340 and it worked like a charm. I can’t seem to get the valve open on the G05 40i. The valve isn’t visible so my only way of telling that the valve is closed is that there is no heat coming from the exhaust, unlike the other side witch pours out heat.
Search this Thread:
Advanced Search
xbimmers
