Quick & easy question re: spacers & anti-sieze
07-10-2008, 08:16 AM | #1 |
386
Rep 2,989
Where should one apply anti-sieze when using spacers. Between the hub & the spacer? Between the wheel and the spacer? Or between both the wheel & the spacer and between the spacer & the hub?
Thanks in advance. |
07-10-2008, 12:08 PM | #3 |
Moderator
369
Rep 4,745
Anywhere but on the lugs themselves.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
07-10-2008, 12:21 PM | #4 |
731
Rep 3,735
anywhere between the hub and the spacer.
Make sure you clean off the surface rust as well. You want to eliminate the hub contour and have a perfectly smooth mating surface.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
07-12-2008, 09:26 PM | #5 | |
1469
Rep 3,553
you can use either antiseize or high temp grease, just make sure you pick one with a high run temp or else it will liquify and run when hot. i use either copper/nickel antiseize (if i have it) or high temp moly brake caliper grease.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
