11-14-2018, 12:00 PM | #1 |
344
Rep 906
Window creaking when fully closed (F30) (yes I searched)
OK guys, help a dude out! I tried searching and do not really find the exact same thing as what I am looking for...
Both my front windows have started creaking very loudly as I drive. I thought it was my door seals but it's not. It only occurs when the windows are fully closed. If I open them even slightly it goes away. So it's the channel where the windows seal closed... It's not my tint either... I've had the tint since I got the car in April and never had this problem. It just started occurring. Any suggestions? I know with seals I would lubricate/make sure they're moist but don't know what to do here.... Thoughts? Thanks in advance!! 2018 330i
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
11-14-2018, 01:23 PM | #2 |
12
Rep 46
there should be a service advisory at the dealer for this; If it’s still under warranty take it in, they will fix it. They will either replace the seals or run a thin layer of transparent tape by the seal to silence it.
11-14-2018, 02:42 PM | #3 | |
344
Rep 906
thanks in advance!
2016 X3 35i M-Sport
11-14-2018, 03:50 PM | #4 |
4022
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
You might want to check your B-pillar trim. I had a similar issue (but it was more of a rattle) that happened only when my windows were all the way up. You can see what I did in my log.
11-14-2018, 11:40 PM | #5 | |
12
Rep 46
11-15-2018, 12:09 AM | #6 |
I want to drive a Zamboni
1132
Rep 5,558
Drives: 13 E93 M3 18 F80 M3 16 K71
Dealer replaced the inner seal rubber and installed Teflon tape on driver door. Problem solved.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
11-16-2018, 11:36 AM | #7 | |
344
Rep 906
2016 X3 35i M-Sport
11-17-2018, 12:53 PM | #9 |
54
Rep 62
This is a known issue and it seems to be happening with the M Sport 330. I had a 2017 330 M Sport and same thing. It progressively got worse too. The dealer had been submitting the issue to BMW but there was no fix yet. They replaced all the seals and did the lubrication routine. It quieted down for a while and then started back up again.
Rolling the window down takes the pressure off the door. It gets particularly bad over some bumps and turning up over a curve. Seems to be a mix of excessive chassis flex and rubbing against moldings that come with the M Sport but I'm not 100% sure. |
11-17-2018, 01:49 PM | #11 | |
18775
Rep 14,121
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
