11-12-2018, 07:24 PM | #1 |
69
Rep 96
MRG titanium stud conversion kit
Does anyone have any experience with any stud conversion kits? I've got a titanium one from MRG race and am thinking about installing it in my F90 in conjunction with my new Brixton Forged wheels but I'm a little hesitant and am curious if anyone has had one of these installed in their cars before and what the experience was. Thanks guys!
11-12-2018, 07:32 PM | #2 |
261
Rep 472
i did on my F82. make sure you go slowly, use a thread chaser before you put the studs in, have a very good high quality hex bit... don't force anything and make sure your torque is spot on.
personally i think the mrg studs look fantastic. a nice pop of bling. |
11-13-2018, 08:02 AM | #3 |
12913
Rep 18,683
On the M5 though??
I would do it on M2/M3/M4, but not feeling it on 5 series and up.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
11-13-2018, 09:38 AM | #4 |
261
Rep 472
11-13-2018, 09:43 AM | #5 | |
12913
Rep 18,683
M5 should looks sleek and clean.
11-21-2018, 05:25 PM | #6 | |
261
Rep 472
01-22-2019, 11:29 PM | #7 |
Rep 6
I am currently running these on my E63. I personally think they look great and sorta regret not getting the longer ones (I think they look better when they stick out). They are very light weight and unfortunately kinda soft (I mounted a wheel a bit crooked and rubbed some of the "titanium" off the threads of one of them). The installation instructions are pretty straight fwd (thread on at 20ft/lb). I have been using them for about a year now and no problems so far. Just remind your mechanics they are not to use impact guns on your shiny wheel hardware or they are buying you a new set.
02-21-2019, 10:40 AM | #8 | ||
69
Rep 96
Here are some pics. |
G30 B581546.50 |
02-22-2019, 10:29 AM | #9 |
1716
Rep 1,909
Drives: 2023 M5C
Maybe I'm missing it, but is there not a lug lock on those wheels??
02-22-2019, 04:22 PM | #10 |
69
Rep 96
02-24-2019, 12:53 PM | #11 |
83
Rep 37
I would be reluctant to install wheel studs on a CCB equipped car. When I had my 997 Porsche with PCCB’s, like the M5, it came with lug bolts. When you needed to remove a wheel, you would first remove a couple of lug bolts and replace them with a couple of long guide studs. Then when you removed the wheel the two long guide studs allowed you to slide the wheel off without fear of the wheel falling on the expensive carbon/ceramic brake rotor. It also facilitated remounting the wheel and again protect the brake rotor.
///M Power-Belgium63062.00 |
02-24-2019, 12:57 PM | #12 | |
69
Rep 96
02-24-2019, 10:32 PM | #13 | ||
Rep 6
01-31-2022, 12:24 AM | #14 |
28
Rep 103
Sorry for reviving an old thread, but this is for anyone who might be in the market for MRG Titanium Studs. Steer clear from them! They may potentially kill you, and their customer service is absolutely terrible when confronted with it. They'll just block and ignore you.
Read here: https://f80.bimmerpost.com/forums/sh....php?t=1676684 |
02-15-2022, 10:09 PM | #15 |
1231
Rep 4,106
I love mine. Swapping wheels is so much easier.
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
02-16-2022, 06:41 AM | #16 |
5212
Rep 10,594
I bought regular grade 12.9 studs, not titanium. I like them for swapping wheels and run stud conversions on my personal cars. I have not had any problems other than buying a cheap set many years ago. Some racers change them periodically but racing puts a lot of stress on them. The ideal conversion are the integrated hub stud conversions with the studs pressed in from the back side like a factory would install studs, but these are much more expensive.
I bought 80mm and honestly think they are a little too long even with spacers. I’d estimate 60 without diapers and 70 with spacers would look better. |
