BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    60-130
      11-12-2018, 05:56 PM   #1
F01Boost
70
Drives: 2012 750i Msport tuned
Seems pretty good
Stage 2 dme and Keller DP
2018 F90 stage 2 dme w Keller performance dp
2018 X5m dme tuned
2015 650 vert dme tuned
2012 750i M Sport JB TUNED- Current
2010 135 vert JB Tuned - retired
Miko M6653.50
      11-12-2018, 06:48 PM   #2
KellerPerformance
111
Drives: M5
Originally Posted by F01Boost View Post
Semis pretty good
      11-17-2018, 05:29 AM   #3
dmmpower
dmmpower's Avatar
32
Drives: M5
With stage 3 without downpipes.
Appreciate 2
Miko M6653.50
soooma1377.50
      11-17-2018, 05:56 AM   #4
F01Boost
70
Nice 100-200 time
What mods do you have for stage 3
2018 X5m dme tuned
      11-17-2018, 05:57 AM   #5
F01Boost
70
More data
2018 X5m dme tuned
      11-17-2018, 05:58 AM   #6
F01Boost
70
Couldn't load the 100-200 pull it was 5.91
2018 X5m dme tuned
soooma1377.50
      11-17-2018, 11:54 PM   #7
MuffinFlavored
79
Drives: 2014 F10 M5 MT
6.73s 60-130mph tuned, what are some average stock 60-130mph times?
      11-18-2018, 05:33 AM   #8
F01Boost
70
Honestly not sure, I got draggy after my tune.
2018 X5m dme tuned
      11-18-2018, 07:23 AM   #9
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
I am number guy
100kmh-200kmh is not the same as 60mph-130mph= 96.561kph- 209.215kph vs 100kph-200kph
Comparing apples to oranges
On dragy you can change on costume screen so you guys can compare the same numbers.
I will post mine too next week
I am on RC which will be slower but it would be nice to compare, I will make a chart too
Stock vs RC vs stage 2/3
Life is too short...enjoy your life
///M
Appreciate 5
onfireX53618.50
soooma1377.50
f90_FTW156.50
M 4EVER191.00
      11-18-2018, 08:27 AM   #10
onfireX5
3619
Drives: F90M5,F85X5M
RC tested 6.22 seconds. 100kph to 200kph. On a cool night. Cool nights make a big difference on turbo cars.
Appreciate 2
Miko M6653.50
soooma1377.50
      11-18-2018, 08:53 AM   #11
Miko M
///M
Miko M's Avatar
Cold air is denser and an increase in HP is normal on any motor. Humidity is a big factor with any temperature. A motor puts out more horsepower at low humidity and low temperature.
Dry cold air packs way more oxegen into your engine than on a hot humid day. The more modifications on your engine, the more horsepower and torque gains.
Altitude above sea level is another big factor. Its called altitude density.
The higher elevations above sea level have an impact on your performance also.
Additionally, humidity changes the results by about 1.85% for every 50% of relative humidity.
Every 1000 feet of altitude changes the result by approximately 4.2%
Every 0.5 inches of mercury (air pressure) changes the result by around 2.1%
1% more HP with each 10 degree drop in temp. This is because cold air is denser than hot air. Dense air has more oxygen. In addition the PCM doesn't pull timing when it's colder, so you can make even more HP
///M
Appreciate 3
soooma1377.50
M 4EVER191.00
      11-18-2018, 12:47 PM   #12
F01Boost
70
Little better
2018 X5m dme tuned
Appreciate 2
Miko M6653.50
M 4EVER191.00
      11-19-2018, 09:49 AM   #13
m6beast
m6beast's Avatar
185
Drives: stock m6
Full weight "sunroof and steel brakes"
1/2 tank gas
Hope to see better times with less fuel and cooler weather
Appreciate 4
flaury23122.00
Miko M6653.50
M 4EVER191.00
      11-19-2018, 06:20 PM   #14
F01Boost
70
1/2 tank gas
Very nice! Race gas?
2018 X5m dme tuned
      11-20-2018, 03:13 PM   #15
koko f90
12
Drives: bmw m5 f90
1/2 tank gas
Mode list please
Very good!!! Crazy fast 👏🏼
It’s 100-200 5.7 something like that
What you did? Just tuning?
      11-20-2018, 05:44 PM   #16
Pimpsy
420
Drives: 2019 M5C
0-60 in 1.5s??? You falling off a cliff??
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
      11-20-2018, 07:22 PM   #17
flaury23
122
Drives: 2014 M5
Not mph.... Kilometers
themnmd1691.00
      11-23-2018, 08:35 AM   #18
m6beast
m6beast's Avatar
185
Drives: stock m6
1/2 tank gas
Well did a little better but i wish i would have run same road, with a better slope maybe see low 6.3's.
Appreciate 3
Miko M6653.50
M 4EVER191.00
      11-23-2018, 09:12 AM   #19
onfireX5
3619
What's the 100 to 200 kph ?
      11-23-2018, 02:24 PM   #20
koko f90
12
Drives: bmw m5 f90
Mode list please
      11-23-2018, 04:54 PM   #21
Miko M
///M
Miko M's Avatar
I figure I share mine numbers which are not even close to any off your's but, I am also not running map2/3, Or any high octane gas.
Big part of having low numbers is winter tires,Humidity
Here is what I am running now:
RC Chip, 91oct gas ( normally I run 93 )
Lower down pipes
Temperature was 48F
Humidity 80%
Pressure 29.5 inHg
Elevation 1030ft
I had the best 0-60 times on winter tires yet 3.05sec.
I also did 100-200kph too which is very low too, did manual shift on this one and it must be spinning enough to slow me down, even dough I didn't feel much
///M
M 4EVER191.00
      11-23-2018, 04:59 PM   #22
F01Boost
70
Lower down pipes
Temperature was 48F
Humidity 80%
Pressure 29.5 inHg
Elevation 1030ft
Hey thanks for sharing
The best times I achieved was in sport plus
All auto, start around 50 and punch it. It shifted on its own. Also especially now make sure you warm up the tires with a nice drive so they can grip.
2018 X5m dme tuned
Miko M6653.50
