Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 335xi Transfer Case Fluid Change DIY
      11-11-2018, 07:30 PM   #1
finallall
Drives: 08 335xi
I wanted to do this DIY since people are having a difficult time removing the fill plug on the transfer case without removing the transfer case mount bracket.
This is the way I did it in 5min without removing the bracket. I did have the exhaust and shield removed since I'm doing other repairs that require it off.
The Bentley manual calls for a 14mm Hex nut socket but I didn't have one. + I read it's impossible to get it in without removing the bracket or cutting down the socket. So I bought a 9/16 long nut from Home Depot. Cost 99 cents. Anyway here is the procedure I followed:
Car on jack stands and as leveled as possible.
Pic # 1 is the long nut 9/16 size or 14mm
Pic # 2 nut installed
Pic # 3 used 14mm wrench to turn
Pic #4 fluid drained into a container. Make sure container is at least 700 milliliters. Their's supposed to be 520ml but I got only 411ml. You can see how black the fluid is. Once drained completely reinstall plug and torque to 44ft/lb.
Pic # 5 Long nut installed on the fill plug.
Pic # 6 used 14mm wrench again to unscrew fill plug.
Pic #7 shows the old fluid @ 411ml. I used a long hose squeezed onto the new fluid bottle to create enough extension to feed the new fluid in. I just raised the bottle as high as I could and squeezed to make the fluid come out until it started to overflow from the fill plug.
Pic #8 shows the level of fluid remaining in the container. It took about 520ml to fill it up which is the proper fluid amount as per the Bentleys manual.
Last Pic # 9 shows I used a crows foot to create enough space to sneak my torque wrench in and torque it to 44ft-lb.
Anyway hopefully someone finds this post useful.
      11-11-2018, 07:43 PM   #2
Needbmwpartzz
Needbmwpartzz's Avatar
851
Drives: 2009 bmw 328i x-drive
what type of fluid did you use?
      11-11-2018, 07:51 PM   #3
finallall
Drives: 08 335xi
Ravenol Transfer Fluid Tf-0870
      11-12-2018, 12:00 AM   #4
Blueeyesredpanda
Blueeyesredpanda's Avatar
401
Drives: E90 / F30
Is this an AT or MT?
      11-12-2018, 10:33 AM   #5
nsjames
2442
Drives: 08 328xi Touring
My only addition is, make sure you break the fill plug free before you drain it.
that's a lesson you learn once.
SG_E9072.00
      11-12-2018, 01:33 PM   #6
finallall
Drives: 08 335xi
Manual.
      11-21-2018, 02:06 AM   #7
Blueeyesredpanda
401
Drives: E90 / F30
Your method can only apply to MT. AT transmission took up more space.
