11-07-2018, 11:02 AM | #1 |
Rep 25
DIY oil change anyone
Do we have members doing their oil changes, and if yes, is there a thread with part numbers for the filter element and gaskets, if any? I don't seem to be able to find one.
11-07-2018, 11:19 AM | #2 |
1729
Rep 3,654
I did the first oil change around 5k on my old m40i.
Don't have part numbers handy but I will tell you that getting the filter out housing is a pain, it is far in the back and requires 32mm socket (1-1/4"). I would probably not do it again on the b58. For reference the filter / oil on e90 is a piece of cake |
11-07-2018, 11:20 AM | #3 |
83
Rep 178
Drives: 2019 X3 M40i
You might have better luck in the First or Second Gen X3 forums. The oil changes are covered under the included maintenance for the first 3 years, so I'm letting BMW handle it.
2019 X3 M40i Alpine White
11-07-2018, 11:28 AM | #4 |
626
Rep 1,044
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
I did mine on my 18M40i. As mentioned, a 1 1/4" socket, swivel and extension worked on my car. Not sure who designed the placement of the oil filter but access is a little difficult. Otherwise, it's a normal oil change procedure. I had the BMW dealer throw in a couple oil filters when closing the deal so I just used BMW parts.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
zaitcev22.00 |
11-07-2018, 01:54 PM | #5 |
Jim
270
Rep 156
I haven't had it enough to change oil in it yet, but have been looking into this. My engine, per MANN is a B46B0O0. And for BMW: https://www.realoem.com/bmw/enUS/sho...87#11428596283
So far I've found for the oil; BMW # 11428575211 Mann # HU6014Z Trying to cross reference for others OH: Fram says it # CH11217 |
zaitcev22.00 TheusBimmer144.00 |
11-07-2018, 07:56 PM | #6 |
272
Rep 496
[QUOTE=arciga18; I will tell you that getting the filter out housing is a pain, it is far in the back and requires 32mm socket (1-1/4").
[/QUOTE] Can you get a torque wrench in there? And no dipstick so we will go by volume only? Haven't crawled under yet to check out the drain plug just thinking ahead, 3 years goes by fast...... |
11-07-2018, 09:56 PM | #7 |
Rep 16
I planned to do an early change but it was a PITA to get info - I called dealers to find out the correct oil and, at least at that time, no one seemed to know. Here's what I found;
https://www.newtis.info/tisv2/a/en/g...nce/1VnYflS6JY |
zaitcev22.00 |
11-08-2018, 06:16 AM | #8 | |
1729
Rep 3,654
[QUOTE=kevinkay;23960057]
Because the car was so new I didn't want to lean over the side too Much in fear of damage. On the m40i the engine is tucked in nicely away from the front so I couldn't reach standing at ground level in front the car: The oil plug underneath was not hard to find. Usual spot / usual cover . I don't have a lift at home . |
11-08-2018, 03:00 PM | #9 | |
Rep 25
Did you find the specification or part number for the "sealing ring"? It goes under the bolt of the drain. |
11-08-2018, 05:27 PM | #10 | ||
2088
Rep 3,006
11-08-2018, 10:18 PM | #11 |
Rep 25
How am I supposed to measure the bolt without unscrewing it? I cannot unscrew it until I have the washer, and I cannot drive the car to the store once I have it out to measure. I suppose I could start this in the morning, then order washers overnight with Amazon Prime, but that sounds a little risky.
11-08-2018, 11:08 PM | #12 |
430
Rep 1,115
Buy the mann filter, it comes with the crush washer and rubber oil filter housing gasket. If you search on here I posted instructions on doing the oil change a few months ago.
11-09-2018, 02:41 PM | #13 | |
11
Rep 38
Here is a link to the drain plug. https://www.getbmwparts.com/oem-part...MtMGwtbDYtZ2Fz Last edited by TC_G01; 01-03-2019 at 11:04 AM.. Reason: added link to part |
zaitcev22.00 |
11-09-2018, 04:23 PM | #14 |
626
Rep 1,044
That makes two of us.
11-09-2018, 07:10 PM | #15 | |
2088
Rep 3,006
And if you really think you're going save that much buying then from Amazon, etc. Yes, unscrew it put your finger over the hole, measure it then put it back together and top off the oil. The washers are good for 2-3 uses if you don't crush the hell out of them but I'm not that cheap and use a new one considering what will happen if I loose the oil in my engine. |
