Bimmerpost
4 Series
Technical Topics Suspension / Chassis / Brakes Are the optional M Sport brakes on the 330i the same size as those on the M340i?
      11-04-2018, 10:30 PM   #1
Prissy
Prissy's Avatar
Taiwan
1065
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
2010 BMW E92  [10.00]
Does anyone know if the M sport brakes on a 330 and a M340 will have the same brake disc dimensions? Thanks.
      11-06-2018, 11:13 AM   #2
beemerlover13
69
Drives: not sure..
I believe they are the same..I have them on my 320i. Only downfall is that they squeal like hell in the winter!!
      11-06-2018, 12:03 PM   #3
Prissy
Prissy's Avatar
Taiwan
1065
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
Yes I believe you are right. And ya mine sqeaked like crazy too lol
      11-06-2018, 12:11 PM   #4
beemerlover13
69
Drives: not sure..
It's terrible, I brought it is because of the noise and my car does has this loud clunk when in reverse only when it's cold out, in took it in 5 times and they don't know what it is.. I gave up but almost positive that it has something to do with the brakes and locking up in the cold..
      11-06-2018, 01:17 PM   #5
xlover
2191
Drives: 2023 X7 40i
On the F3X the 330 msport brakes (blue caliper) = standard 340
340 msport brakes (blue caliper) are bigger than standard
However with no standard model m340 the blue caliper msport upgrade for the 330 could be the same. I think more likely is there will be an intermediate size for the 330 but still smaller than the M340
      11-07-2018, 07:29 AM   #6
pruettfan
1622
Drives: 2017 M2, LBB, DCT, Exec
All of the blue calipers are the same (Brembo) they are used in the M2,M3, M4 and as an option on most other BMW models. The squeaking discussed above is because of the pads not the calipers, basically the moisture creates a rust layer and you have to generate heat to work that layer off. Not a big issue. There are some very good aftermarket pad options that not only resolve this issue but also reduce brake dust.
      11-15-2018, 07:06 PM   #7
JamRWS6
191
Drives: 2022 X3M Competition
+1
The only difference is the size of the rotor paired with that caliper is different between the applications. I.e. the rotors on a F30 340i with the blue M-Sport brakes are smaller than the rotors on an M3. Same calipers though.
- 2022 X3M Comp
- 2021 X5 xDrive 40i
- 2018 F80 M3 (sold)
      11-16-2018, 04:32 AM   #8
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
Sounds like you're describing the brake pads shifting. Nothing to worry about. This is not unusual in fixed caliper braking systems.
      11-16-2018, 08:28 AM   #9
mosto
Drives: F30 LCI 330i M sport
on mine f30 330i dimensions of msport brakes are: front rotor 370 mm with 4 pistons caliper, rear rotor 345 mm with 2 pistons caliper.
      09-19-2021, 05:32 AM   #10
Dereli
Dereli's Avatar
Denmark
81
Drives: Bmw M3 E92
Hi
I have a 2021 330e with M breaks and they make a terrible noise when I stop for red.
Which aftermarket brands would you recommend to solve this issue here, Bmw Denmark is not working very much for solving this problem.
      09-27-2021, 03:34 PM   #11
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
That was true for F series but totally different for G series.
For G series
M3/4 Calipers are a totally different design than regular 3 series, I think they are based on Brembo GT calipers like the ones Porsche uses.
M340i Track Pack calipers are basically 5/7 series and also X3M calipers but using different sizes rotors depending on application.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
g20
