11-04-2018, 06:18 PM | #1 |
61
Rep 102
M550i engine lubrication service campaign
Received a letter telling me to schedule a service appointment for "new software, with an improved engine lubrication strategy." It says "your vehicle will be programmed with the newest engine software. In addition, various engine mechanical components will be inspected and replaced, if required, with improved parts." It also says programming will take two hours unless "additional components need replacement."
Anyone know what this is about? |
11-04-2018, 11:29 PM | #3 |
11
Rep 33
I’m dropping mine at the dealership tomorrow for this. Apparently they are also changing the oil lines that go to the turbos? Not sure if this is part of the same recall or not.
11-05-2018, 01:41 AM | #4 |
Rep 29
recall M550i
I recieved the same letter. Dropping in to my dealer this week. They say the job includes re-Programming the engine software and inspect the oilpipes to the turbos. I`ll Guess this is connected to the enginefailure and the issues many M550I have, where they need to replace the whole engine after some engine damage ? Or maybe not ?
11-05-2018, 03:34 AM | #5 | |
52
Rep 162
Had the fix done, took 1/2-day. I just remember they were very vague about what needed to be done and why, and whether it was a pure software update or a mechanical intervention also. I'm still none the wiser but assumed it relates to the engine control. And I can tell you that when I got back in my car, every iDrive setting had to be re-programmed.
M550i xDrive delivered June 20 2017
11-05-2018, 06:28 AM | #6 | ||
472
Rep 888
Drives: 2019 M550i
11-05-2018, 07:26 AM | #7 |
376
Rep 1,223
I assume this will wipe out any user coding?
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
11-06-2018, 06:55 AM | #8 | |
52
Rep 162
The closest they got was "it will be an update of the vehicle".....I'm just guessing it was something that needed a fix, a kind of recall, emissions perhaps, legal reasons, they were certainly quite coy about it. And now they stopped producing this model at all.........
11-07-2018, 10:38 AM | #10 |
3398
Rep 6,589
Drives: BMW
Received my letter this week as well. Scheduled for service on the 20th. I guess the N63TU2 still has gremlins like its predecessor(s)?
Other forum convo on this as well: https://www.bimmerfest.com/forums/sh....php?t=1299855 Last edited by forza1976; 11-07-2018 at 10:43 AM.. |
11-30-2018, 06:12 AM | #12 |
Rep 2
2018 M550i "Recall" Customer Campaign
Brought my 2018 M550i (5,800 miles) to dealer this week for this "software update." When I picked it up I checked the BMW Connected Drive APP and noticed it was giving me erroneous readings. It indicted that the front windows were down (they were not) and that the hood was opened (it was not). Also, am unable to send any commands to the car from the Connected account. Cannot lock/unlock, ventilate or view cameras. Rubbish! When I told the dealer about this, here is their response: "I just spoke with the both shop foreman, they just received another update from bmw overnight that they will be uploading over the weekend. They are both in agreement that it is more than likely a software issue in the new update. They have had 5 updates from bmw in the last 6 months fixing found concerns. If you can make it through the weekend.”
Does this sound like a messed up organization, or what? |
11-30-2018, 09:37 AM | #14 | ||
Rep 7
TLDR - they replaced the oil lines for the turbos and updated the DME. I had to restore a few iDrive settings. As to performance - absolutely no difference noted. Still as fast as ever Details: One of their master technicians came out and showed me what they inspect, replace, perform, etc.: 1. Inspect oil line for each turbo - apparently the non-braided (rubber insulated) lines have a possibility of leaking over time. If they find one they will replace it with a braided line. He inspected mine in front of me and found I actually had one of each. How odd! Even surprised him. 2. Inspect a small gasket right under the engine cover for some liquid residue(coolant?) - If they find that it means something needs to be replaced. I can't remember what would need to be replaced since he inspected it in front of me and said it looked fine, but said it look like white salt around the gasket and it would be very obvious. 3. Will update software version in the DME - he did not have any additional information and said they don't really get details on what's included, just that it needs updating. |
11-30-2018, 10:58 AM | #16 |
376
Rep 1,223
The DME update is a separate service campaign (SIB:B122418). It stated it was to "improve engine lubrication strategy". I got that one but not the replace hardware one, which is a different SB.
12-01-2018, 05:21 AM | #17 |
Rep 2
Engine Lubrication Strategy software update
Since this campaign started, there have been 5 different software versions/Updates because of bugs and glitches. So, depending on when you had this done, you may be going back to have it redone. This is BMW at its finest. I remember the original N63 Campiagn.... what a nightmare
12-01-2018, 06:28 PM | #18 |
176
Rep 152
Drives: '22 Dark Graphite M5C
Just had my engine lubrication fix accomplished last Friday & Saturday. On Tuesday morning, I got a check engine light and took the car in for service Wednesday. Apparently the software has done something to the front grill actuators and they are stuck open. They are ordering new actuators and will replace them this week.
If it's a software problem messing with the actuators that worked just fine before the software update, I'm convinced it's probably going to happen again. Frustrating to take the car back for a 3rd time over the course of a week and a half when it was running perfectly. Last edited by DGM M5C; 12-01-2018 at 07:36 PM.. |
12-03-2018, 07:12 PM | #21 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,208
12-03-2018, 07:54 PM | #22 | |
176
Rep 152
