11-02-2018, 02:15 PM | #1 |
3512
Rep 2,044
Performance Exhaust Loudness Rankings, pls?
Hello BMW Experts!
I'm thinking of putting a fancy exhaust onto my 2017 330i. Since I won't feel the HP gain, my other criteria are weight, which differs only a little bit, and sound! I only have found one site that rates exhausts for sound volume: https://www.carid.com/2017-bmw-3-ser...er=1&sub-model[ourBodyTypeName][]=Sedan But they only have two levels, moderate & aggressive/loud. I would like a better than stock, but not much louder. This leave two at that site, the Magnaflow Touring & the AWE Touring. Can anyone give a ranking of the loudness of different exhausts, or offer an informed opinion of such, pls? TIA! Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
11-02-2018, 03:50 PM | #2 |
2001
Rep 3,680
We made a small ranking (still ongoing if people continue to make entries) regarding this exact topic and measuring N20/N26 exhaust setup decibel levels. Here is the thread: https://f30.bimmerpost.com/forums/sh....php?t=1543943
I know that is talking about the N20/N26 and not the B48, but I think the results would be similar. That aside, from what I know about and my experience with the MPE, it sounds like it would suit your needs well. When I ran it as my sole exhaust modification on my 328i it was pretty mild as far as volume but dramatically improved the actual sound of the exhaust note. Judging by what you said about what you'd like, I think the MPE should be the first place you look.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
Littlebear3511.50 |
11-02-2018, 05:59 PM | #3 |
3512
Rep 2,044
Hi rjdnyy224,
Thanks, that is an interesting read. I imagine there are a few probs with consistency between cars, instruments, & environment. I wonder how cruising decibels could be estimated by these measurements. I guess the MPE is the most mild loudness upgrade. The 335i muffler is a quiet cruiser, but is that a quad tip which would need rear valence cutting?. If anyone can comment on some Magnaflows, that would be cool. TIA! Murf Last edited by Littlebear; 11-02-2018 at 06:28 PM.. |
11-02-2018, 09:31 PM | #4 | |
2001
Rep 3,680
And yah a 335i muffler would require some sort of modification to the rear valence to accommodate the dual outlet.
11-03-2018, 12:05 AM | #5 |
724
Rep 943
Drives: F30 328i Msport
I have the MPE and it is indeed quite quiet, I’d say around 10-15% louder than stock tops, thinkingnof putting back on my muffler delete.
11-03-2018, 08:45 AM | #6 |
3512
Rep 2,044
[QUOTE=rjdnyy224;23938600... I would venture a guess that the MPE is one of the quieter options, with Dinan undoubtedly being the quietest.
[/QUOTE] From reading here, opinion on volume seems to be MPE, Dinan, mild, then AWE being quite loud. But the linked Carid page has Dinan being noisy, with AWE & Magnaflow "Touring" being less loud. Murf |
11-03-2018, 10:53 AM | #7 | ||
2001
Rep 3,680
Noelified228.00 |
11-03-2018, 11:15 AM | #8 |
8264
Rep 16,111
It's far more involved than that, based on the pitch of the sound. We don't hear all frequencies as equally loud. Far from it. You can have a low frequency tone, say 100Hz, and a midrange tone, say 1000Hz, measure exactly the same, but the 1000Hz tone will be heard as being as much as four times as loud as the 100Hz tone. That being the case there's no quick and easy method of comparing exhaust tone or perceived loudness via a simple SPL measurement alone.
11-03-2018, 02:24 PM | #9 | |
2001
Rep 3,680
11-03-2018, 03:14 PM | #10 |
98
Rep 227
Drives: 2000 BMW E39 M5
I have Supersprint's dual-tip catback exhaust with resonated mid-pipe on my B46. It's probably 20% or so louder than stock with subtle burble on upshifts and over-run. I'm glad I got the resonated mid-pipe because there's absolutely zero drone. Also looks great.
Overall happy with it despite the price and custom fabrication needed to make it fit up to the OEM B46 downpipe. Supersprint designed their mid-pipe for the B48, which has a different connection between the downpipe and mid-pipe than the B46. Last edited by Sweeney921; 11-03-2018 at 03:20 PM.. |
11-03-2018, 03:47 PM | #11 |
8264
Rep 16,111
It's not. Most mufflers are Helmholtz resonators. That means they can be tuned to reduce specific frequencies more than others. You can have ten different mufflers tuned to ten different frequencies, with ten very different sound characteristics. That means you can also have ten different exhausts that all measure the same average SPL but are heard at ten different volumes. Or you can have ten exhausts that sound the same level but measure at ten different levels. This is why most noise statutes are doomed to failure. The level of expertise and gear required to successfully enforce them are way beyond what not only the average cop has at his disposal but also the average inspection station.
11-03-2018, 05:09 PM | #12 | |
2001
Rep 3,680
Also, because frequency affects only our perception of how loud something is and not it's actual SPL, I would still consider decibel testing to be objective. Some things with different frequencies may sound slightly louder or quieter than others even if they register the same SPL, but it will at least give us a rough estimate. If that weren't true the decibel scale would be completely moot.
11-03-2018, 05:40 PM | #13 |
8264
Rep 16,111
It's not moot, but it's far from perfect. It was literally invented by Bell Telephone to measure the volume losses incurred over long telephone lines, so they would know how far apart they had to place volume boosting repeater stations. They never considered the effect of equal loudness, as all they cared about was the limited frequency band width of telephone transmission. Equal loudness studies came along much later, in 1933, after the advent of movie sound. If the decibel scale and the methods of measuring sound levels had been invented by RCA or Western Electric instead of Bell Telephone it would probably be very different, but it's way too late to turn the clock back now.
Noelified228.00 |
11-03-2018, 05:59 PM | #14 | |
2001
Rep 3,680
Noelified228.00 |
11-03-2018, 08:23 PM | #15 | |
228
Rep 325
Drives: 2016 F36
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
rjd_F302000.50 |
11-03-2018, 08:31 PM | #16 | |
2001
Rep 3,680
11-03-2018, 08:38 PM | #17 | |
228
Rep 325
Drives: 2016 F36
https://www.facebook.com/events/1126343787542661/
11-03-2018, 09:50 PM | #18 | |
2001
Rep 3,680
11-04-2018, 06:05 AM | #19 | |
3512
Rep 2,044
I'm tempted by the Dinan. Most of my driving is on long hiway trips up to the mountains. Five hours with a loud exhaust can be annoying, no matter how good it sounds in the mountains.... If the Magnaflow "Touring" is almost as quiet as the Dinan, that could be cool (love my new Dinan springs)! Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
rjd_F302000.50 |
