BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    AWD and tire replacement
      11-01-2018, 01:15 PM   #1
fstezaws
91
Drives: 2020 911 S — 2022 X5 M50
As a former Subaru enthusiast, it was incredibly important to always have equal tread depth on every tire to prevent screwing up the diffs.
Since the AWD on the F90 isn’t always full time, does this still apply? Can you treat tire replacements like you could on any RWD? I’m wondering if this is the case since the front tires are slightly different sizes than the rears.
      11-01-2018, 06:04 PM   #2
zuschnell
zuschnell's Avatar
556
Drives: '19 m5, '18 991.2 gt3,
More important for equal tread wear on the front pair and the rear pair, not all four at the same time. The fronts won't wear as much as the car is still rear drive until traction necessitates the front to intervene.
Gone but not forgotten: '10 X5M, '14 550ix, '17 M3 zcp, '11 aw e90 M3 zcp, ?11 sg e90 M3, '17 X5M, 19 F90 M5
Current: ?13 e92 m3 ESS 585, 22 f95 x5m Comp, Track - '18 manual 991.2 GT3, Wife's family truckster - '20 Volvo XC90 T8
      11-01-2018, 06:30 PM   #3
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Normally you need to stay within 3/32"( 2.38 mm ) front to back for AWD
Interesting is that you can drive the car as RWD to and do burnout
But after while what happened with rolling diameter being off
I guess if you noticed the big difference you just change it to RWD until you get new set.
So nice like a switch, on/off
Life is too short...enjoy your life
///M
      11-01-2018, 08:24 PM   #4
Miko M
///M
Miko M's Avatar
For people that are concerned about rolling diameter, here are some numbers to compare from 275 to 285 size both are on 35 and 20" wheels ( this is calculated formula )
On first picture there is a note about width of the rims. Which stats that generally tire width will change 2/10 for every 1/2" in rim width
///M
      11-01-2018, 11:14 PM   #5
brad850csi
1316
Drives: 16 F13 M6 Comp
Note that the winter setup is the same tyre all round for 20" and for 19" you can run 265/40r19 and 285/40r19 as a setup as well - all sanctioned by BMW.
Lemetier might be along to confirm the details on how to configure idrive for this soon.
      11-02-2018, 10:34 AM   #6
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Reading all these posts makes me feel glad I live in Miami. No winter here ....
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
