MY 2009 E92 Wont start
11-01-2018, 11:53 AM | #1 |
Rep 18
Good morning i been having issues starting my car and im getting a FUEL PUMP message on my I-DRIVE screen, so i took it to my local dealer and they said that NO faulty codes were found there for my warranty company wont pay for the job so i took the home and i did start for like a week and half with no issues now the problem came back..... (it start but only with a trick from a friend bmw owner that is hitting the back seat where the fuel pump is located) any suggestions on what it could be the issue and why they didnt found any faulty codes also i was reading that the MASS AIR FLOW SENSOR could affect the start up of the vehicle not giving faulty codes
11-01-2018, 12:40 PM | #2 |
1917
Rep 13,113
which motor do you have? N52 or N51
Always check the battery first. Does it turn over ? Does it turn over strongly? It would be good idea to get some diags that show BMW shadow codes. Bimmergeeks.net cable is suggested. No fuel pressure might be the problem it won't throw codes for that I think I have seen here before . The usual no start problems. battery starter ground strap from motor to chassis N51 gas tank is subject to the internal fuel lines breaking. This is covered under warranty in the state it was purchased in normally . This motor has a 15 year warranty on anything that has to do with the SULEV portion of the motor or emission system. Last edited by ctuna; 11-01-2018 at 12:51 PM.. |
11-01-2018, 01:05 PM | #3 |
573
Rep 870
Drives: 2009 335i E90
And did you show that to the dealership?
Sounds pretty obvious the issue wasn't happening when the dealership had the car, or they're incompetent. Either way, either take it back while it's experiencing the problem, or have someone else look at it.
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. |
11-01-2018, 02:06 PM | #5 | |
2717
Rep 4,055
I assume (because you have a "FUEL PUMP message") that the starter cranks the engine but the engine does NOT fire, at least for a long time? If so, does the starter crank the engine at the same speed/RPM as before? Is there ANY sputter or attempt to start, or does it just crank at uniform speed? When you say "hitting the back seat where the fuel pump is located, are you hitting the seat cushion (bottom) or the seat squab/back, and on which side? Have you learned how to distinguish the sound of the fuel pump running when the car is quiet -- NO radio or other audio distractions? Do any of your "BMW owner friends" have INPA or other BMW-specific software or scan tools? INPA or other BMW-specific software or scan tool can connect to the EKP (Fuel Pump Module) and monitor (or activate) pump operation, including voltage, amps, setpoint speed, RPM, temperature, pressure regulator signal, etc. and also read any faults stored in the EKP. You may simply have a loose connection somewhere in the pump wiring/circuit, or the pump itself may be failing. If hitting the seat on the passenger/Right side causes the car to start, AFTER it has just cranked for 5 seconds or more with NO sputter, then SOMETHING related to the fuel pump appears to be the issue, but it could be a loose connection, issue with the EKP (Fuel Pump Module), bad connector at the tank, etc. Your N51, SULEV model has a different tank & pump setup than the N52, and it ALSO has a 10-year warranty on some fuel tank/pump components, so you need to research that and get competent advice from someone who has been down that path with a SULEV. There are a number of threads on this & Bimmerfest forum related to SULEV fuel tank/fuel pump issues and the warranty. Do NOT expect BMW or anyone else you may have a warranty with to volunteer to diagnose & fix it on their dime. YOU will have to present your case with KNOWLEDGEABLE diagnosis of your issue and specific identification of COVERED part(s) under the warranty. BTW, do NOT believe everything you read. The car will start with the MAF DISCONNECTED -- IF your fuel pump is running, that is. Your concerns should be: (1) WHAT is causing the fuel pump to NOT run, intermittently, AND (2) if fixing that requires anything more than fixing a loose wire or connection, are the parts covered under the SULEV warranty? George Last edited by gbalthrop; 11-01-2018 at 02:14 PM.. |
11-01-2018, 03:07 PM | #6 |
Rep 18
YES it does crank at start, and im hitting the rear passenger side bottom cushion, i have no idea how the fuel pump sounds like, also i have a heavy shaking at start for like 3 seconds i dont know if this issues are related
thanks George for all your help! |
11-01-2018, 05:56 PM | #8 |
1917
Rep 13,113
to go further is seem you will have to look at the
fuel tank area rather than just hitting the rear seat. The rear seat bench comes up pretty easy just by pulling up on the front of it on both sides. No sure if that gives access to the Tank but you might see something. Check this thread out https://www.e90post.com/forums/showt...&highlight=N51 n51 has a long warranty that covers it for a lot of things because of emissions. Last edited by ctuna; 11-02-2018 at 12:29 AM.. |
11-02-2018, 12:23 AM | #10 | ||
2717
Rep 4,055
https://www.newtis.info/tisv2/a/en/e...system/uL5g1L7 TIS circuit diagrams are "interactive" which means you can click on a BLUE component ID# (e.g. X13845, the connector at the tank) and get more information on that component, such as "Installation Location" or "Connector View." Here are the "Connector View" and "Installation Location" for the tank connector, X13845: https://www.newtis.info/tisv2/a/en/e...i-cou/DigJtr4P https://www.newtis.info/tisv2/a/en/e92-328i-cou/RabKZhX As you can see, the connector is beneath the Right-Rear passenger seat cushion (where you are striking the cushion). The pump itself is at the bottom of the tank below that connector, and here is what it looks like: https://www.autohausaz.com/pn/16147194207 The EKP is located behind the trim panel outboard of the R-R seatback: https://www.newtis.info/tisv2/a/en/e92-328i-cou/Rh3NfRD Here's the TIS Procedure for changing the N51 Fuel Pump -- Note the photos and instructions on how to remove seat cushion, cover plate, and then view of the connector (additional wires >2 are for fuel level readout, L & R sides): https://www.newtis.info/tisv2/a/en/e...l-pump/OxnkwDf It would appear that you have an intermittent wiring fault at the pump (based upon the fact that striking the cushion at that location causes the pump to run). The rough idle for several seconds after startup is probably due to time required to expel air from the fuel rail, since the injectors operated during cranking BEFORE the pump developed/maintained rail pressure. Intermittent electrical faults are difficult to locate & identify, and a dealer would probably just throw parts at it, beginning with pump, and/or EKP, charging $400-$500 for each, plus labor. I would recommend assessing the situation yourself, by removing the seat cushion, the access cover, and inspecting the wiring at the 6-pin connector (X13845), pins #6 (Red wire, 12V+ from EKP) and #5 (Brown wire, ground via EKP). The other 4 wires are for the fuel level senders (R & L sides), and therefore are NOT relevant to your issue as they are independent of pump function. WITHOUT starting the engine, just with the ignition on, try jiggling those wires to see if the pump runs, and/or disconnect/ reconnect the connector checking for corrosion and cleaning with electronic contact cleaner as needed. Take photos, make notes, and report back. George Last edited by gbalthrop; 11-02-2018 at 12:28 AM.. |
