10-28-2018, 05:08 PM | #1 |
80
Rep 239
Headlight issue on G02
Hey guys, I know this isn't an X3 but that forum is pretty dead...
Took delivery of our custom built X4 M40i. Passenger side, inner DRL is dead/yellowed... Pretty certain the headlight is going to need replaced but wanted to know if anyone else had this issue on their X3? TIA |
10-28-2018, 05:34 PM | #3 |
80
Rep 239
It was on I think at the dealer. However, once we hit the road I saw in my rear-view that the passenger side lights didn't look like the drivers side. Messed around with a bunch of switches and no change...
10-28-2018, 06:08 PM | #5 |
121
Rep 165
Aren't you the guy that didn't let the dealer do the full PDI with the dealer? If so, I'd take it back to them and let them do the 2-5 hours of prep they are supposed to do.
10-28-2018, 07:35 PM | #6 |
80
Rep 239
10-28-2018, 07:37 PM | #7 | |
80
Rep 239
Vehicle is going back. Monday they are calling to make an appointment. |
10-28-2018, 07:54 PM | #8 |
709
Rep 1,066
You can’t really open up the headlight. They are sealed with a glue from the factory. The only way to remove the lens is to put it in the oven to heat the glue for removal. I’m sure you don’t want to put an expensive headlight like that in the oven. 😉
10-28-2018, 07:59 PM | #9 |
80
Rep 239
I figured it was sealed but I can see two heat syncs on the headlight. Figured maybe if I removed those there MAY be some internal access, but doubtful. They appear to be held on by torx screws. May not hurt to try but not sure how to remove the headlight.
10-29-2018, 06:43 AM | #12 |
259
Rep 453
trust me, the dealer that made you take delivery with a fault light on, will look for any excuse to blame you for anything wrong. DO NOT fix this yourself. and fyi next time you're taking delivery of a BMW do not accept it with a fault light on no matter how far you drove
11-06-2018, 08:19 PM | #13 |
80
Rep 239
So the headlight was melted inside... That's why it looked yellowish because the lens was BURNT. I'll say it was a freak occurrence and hope no one else will have this issue. Just wondering how it burned the way it did.
11-06-2018, 08:27 PM | #14 |
1729
Rep 3,654
So headlight assembly ordered / or already replaced . ?
11-06-2018, 09:11 PM | #15 |
80
Rep 239
11-06-2018, 09:43 PM | #16 |
The limit of adhesion is my home.
1702
Rep 3,778
This is what a warranty is for Pick it up and enjoy the ride!!!!!
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
