2010 2011 BMW 5 Series Forum F10 Help in changing plugs for my 2013 535i |
10-28-2018, 12:38 PM | #1 |
Retired US Army/Police Officer
30
Rep 161
Drives: F10 M-Sport, E-92
I’ve been searching for some instruction on changing out the spark plugs on my 2013 535i. Is there a DIY for the changing of the plugs? The problems I am looking at on the 535i is getting to plugs 5 and 6 and removing the big plastic tubing that’s runs down on the right side of the engine which is blocking access to 5 and 6 plugs. There is also a small tubing that runs across the engine that will be in the way. I tried squeezing the connector to remove but it wouldn't come off. Is it a squeeze and pull or squeeze and turn. I appreciate any heads-up problems I might run into.
318IS-330IC-E90-E92 328i F10 535i M
10-28-2018, 01:03 PM | #2 | |
310
Rep 716
10-28-2018, 01:42 PM | #3 |
9159
Rep 14,521
huh...tried finding a YouTube video for you but found only for the 550i and for the N55 335i but nothing for the F10? I'm sure it's still similar to the N55 335i tho
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
10-28-2018, 06:44 PM | #4 |
30
Rep 161
Having some problems getting these two connectors disconnected. In the top picture I can see three clips is there another one on the bottom? Do you just pull it apart once the connector clips are released?
In the bottom picture the connector is round and on the release clip it has ridges on opposite sides. I squeezed it and try pulling up but it wouldn't come off. I didn't forced it because I didn't want to break it. Can someone advise how these come apart. I am trying to remove these items to get that side plastic pipe/tube out of the way to change the plugs. Thanks.
10-28-2018, 07:49 PM | #5 |
4484
Rep 5,366
You have the correct procedure. You might have to GENTLY twist while you pull. There is a YouTuber called ShoplifeTV or sometning like hat. He pretty much specializes in BMW's and I've seen one or three on how he removes these type of connectors. He also says you can contact him with questions.
Worth a shot... |
10-28-2018, 08:07 PM | #6 |
231
Rep 5,691
Top picture, yes ther is also a fourthtabon the bottom. Be careful as they like the break.
Bottom picture, squeeze the two knurled sides and pull up. No twisting as mentioned above. And then once those are removed the real fun will begin. |
11-01-2018, 04:54 AM | #7 |
21
Rep 64
When I changed my plugs, I just removed the Torx screws in the first photo. Like you it was a bit of a challenge to remove it using the clips. You will have access with just the screws removed.
11-01-2018, 10:14 PM | #8 | |
431
Rep 915
Drives: 2017 540i Bluestone Metallic
Instgram @burninja
11-01-2018, 10:49 PM | #9 |
4484
Rep 5,366
For a guy that's barely an adult (I believe he's something like 21) he has a TON of knowledge and experience! And to have a girlfriend that helps him work on the cars in his shop.... PRICELESS!!!!! They swapped an LS3 into her 3-Series!
11-03-2018, 01:13 AM | #10 | |
431
Rep 915
Instgram @burninja
11-07-2018, 05:18 PM | #11 | |
132
Rep 318
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i '19 G01 X3 | Wife's '15 F30 335i M-Sport | Son's '10 Porsche Boxster |
