10-25-2018, 01:39 PM | #1 |
448
Rep 525
2019 X3 M40i Delivery tire pressure
Just picked up this car last week and the tire pressure seems to be way too high at 39 psi front and 45 psi rear cold.
The numbers show at the door are 33 psi and 38 psi rear cold. Any thoughts? Thanks! |
10-25-2018, 01:40 PM | #2 |
82
Rep 432
10-25-2018, 01:55 PM | #3 | |
448
Rep 525
10-25-2018, 02:22 PM | #4 | |
10995
Rep 32,881
I usually inflate the tyres to somewhere between the two figures. |
10-25-2018, 07:04 PM | #5 |
138
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
TPMS isn't always accurate. So double check with a quality meter. I once got my car back from the dealer and my tire pressure was 50psi! Idiots.
10-27-2018, 11:05 PM | #7 |
448
Rep 525
10-28-2018, 06:10 AM | #8 |
316
Rep 343
Drives: '19 750i xDrive
It always comes over inflated from the factory, or at least that has been my experience.
10-28-2018, 07:33 AM | #9 |
607
Rep 969
Cars are always shipped with the tire pressure high, and it's often left high while the vehicle sits on the lot (to avoid flat spots). It should be lowered before delivery. ANd if you're like me and live in an area with frequent seasonal temperature changes, you will probably be adjusting pressure monthly.
My TPMS reads low (by 2-3 psi) compared to an AccuTire digital gauge I have. I want to get another gauge for a third opinion to see which is right. TPMS can be calibrated to a known pressure if it's determined that is the issue. |
allen3ybq448.00 |
10-28-2018, 01:19 PM | #10 |
626
Rep 1,044
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
The pressures are high from the factory. They should have. Been adjusted during the pdi. Just correct it with an accurate tore gauge. Don't rely on the tps monitor readings.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
allen3ybq448.00 |
