10-25-2018, 10:58 AM | #1 |
Rep 12
Drives: 2019 X3 M40i
2019 X3 M40i Brakes
So I picked up my 2019 X3 M40i about 2 weeks ago and now have been experiencing a lot more travel in my brakes from when I picked it up. I researched and BMW has a recall on the brakes for too much travel due to bad fluid or bad rear pads. Has anyone else experienced this? I'm taking it in today but wanted to know if anyone has had it fixed?
10-25-2018, 01:13 PM | #2 |
83
Rep 178
I've had mine for about 2 weeks as well, but haven't had any issues with the brakes. I don't see any recalls for mine when I checked the website. Is that info posted somewhere else?
2019 X3 M40i Alpine White
10-25-2018, 01:31 PM | #3 | |
186
Rep 506
You can check to see if your car is in the recall here: https://www.bmwusa.com/safety-and-emission-recalls.html Just put in your VIN. But it seems like you would have gotten a snail mail notice by now if it was in the recall. |
10-25-2018, 03:04 PM | #4 |
Rep 12
Took it into dealer and my guy said they were fine. It still think they feel "soft" but we'll see. There is no recall on my build but I feel the same issue as described in the article I read. When I first picked up the travel in the brake was much shorter for braking then it is now. Time will tell. Thanks!
05-21-2019, 07:31 PM | #6 | |
136
Rep 357
When doing that, my Brembos lasted boringly forever, replacing a front set at 100,000 kms and 29.1 vs min 28mm due to sagittal rust (after inspection turned out superficial). Machined the rear, rust gone, they will last at least to 160,000 kms and on my 5th year of ownership! With track events, what should need replacing, is pads, and brake fuel. Outside brake event, fluid every 2 years and, driving relative, regular bedding cycles. BBKs NEED bedding, a step first time BBK owners learn the hard way when replacing rotors at 20% projected life due to not.. braking.. |
