BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Winter Tires for 530 BMW OEMPart
      10-23-2018, 09:44 PM   #1
kennyar
Drives: 2019 530e
In preparing for the snow and having quite a good experience with Winter tires I finally decided to pull the trigger and order them.
Does anyone has experience in BMW OEM package with 18 inch wheels and Michelin Pilot Alpin PA4 ZP Run-Flat.
BMW seems to have some kind of sale going on for these as there with all the options and OEM rims are cheaper than what you can get from retailers like TireRack.
      10-24-2018, 08:43 PM   #2
AlphaOmega4
Drives: YMB M4
Post link.. I need to order winter wheel and tire package asap, thanks
Not sure if going 18 or 19
Currently on 20" with msport brakes snd summer performance tires..that def will not work
      10-24-2018, 09:11 PM   #3
kennyar
Drives: 2019 530e
https://www.shopbmwusa.com/PRODUCT/6...-TIRE-ASSEMBLY
      10-25-2018, 08:50 AM   #4
Trevster
Trevster's Avatar
Drives: 2014 428xi
This kit is sold pre-assembled for easy installation and the wheel and tire combination is approved by BMW for G30 5 series models (Excluding vehicles with M Performance brake retrofits).
So does that mean any M brakes factory or port installed won't fit with these?
      10-25-2018, 09:14 AM   #5
emre
emre's Avatar
Turkey
85
Drives: G30 540i xDrive
MSport brakes and M Performance brakes are two different products.
M Performance brakes require minimum 19" wheels but 18" are fine with M Sport brakes.
G30 540i xDrive M Sport MPPSK / BM3
      11-12-2018, 07:45 AM   #6
Bebespapa
Drives: 2018 530e
2018 BMW 530e  [0.00]
Has anyone bought this setup from their dealer? If so, did you install the wheel/tires yourself and did the TPS work?
FYI, they also have a set of Michelin X Ice that is about $500 cheaper. Near as I can tell the only difference is the speed rating of the tires.
      11-13-2018, 06:30 AM   #7
NTTY
NTTY's Avatar
Switzerland
37
Drives: G30 M550xi
The Michelin PA-4 are among the best, on my perspective. I need to go to a ski resort station every day, and I would not consider any other tires. They are less efficient in Run-Flat because of too hard sidewalls (be careful in a turn), but they still offer lots of traction.
They are more "sport oriented" than the X-Ice, so they will potentially last less time, but will offer a better performance on non-snowy roads.
Cheers
2018 M550i Sepia-Violet
5post
