BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Can you activate AWD Sport in MDM?
      10-21-2018, 10:30 AM   #1
CarlosM4
Brazil
411
Drives: C63 AMG
AWD Sport is only available with DSC Off right?
I have specced and I am about to order my brand new M5. This is the only thing I haven't been able to confirm with my dealer.
Regards
      10-21-2018, 10:31 AM   #2
kdeleon
94
Drives: M5
AWD Sport is available in MDM mode.
Appreciate 2
CarlosM4411.00
      10-21-2018, 01:46 PM   #3
brad850csi
1316
Drives: 16 F13 M6 Comp
Only time you can't have DSC enabled is 2wd mode.
I think that MDM and 4WD Sport would be the setting I'd run the car on most of the time. I've driven an F90 in the snow and with that setup you could easily have the car 20-30 degrees sideways just like with MDM on my F13.
Carlos, do you get Euro or US spec MDM over there?
CarlosM4411.00
      10-21-2018, 03:17 PM   #4
CarlosM4
Brazil
411
Drives: C63 AMG
Euro spec mate, thanks god. The DSC fully on is too intrusive at least in my F06. Although in the F90, the systems do seem a lot more integrated with the traction and power.
      10-21-2018, 03:18 PM   #5
CarlosM4
Brazil
411
Drives: C63 AMG
Nice, thank you very much. Now I know what will be my M1 and M2 settings LOL.
M1 Efficient, Comfort, Comfort all on
M2 Sport+, Sport+, Sport+ AWD Sport and MDM
      10-21-2018, 03:47 PM   #6
kdeleon
94
Drives: M5
Actually, I wouldn't do M1 like that. That is the mode when you start the engine. So if your M1 is set to something else, you can engage it by pressing and then if you press M1 again, it will go back to that default of all comfort.
So I use M1 as an in between. Slightly sportier but basically my daily driver mode. Then M2 is like you more sporty with AWD Sport and MDM. Then when I'm on a long trip, I leave it all comfort which is the default when the engine is started. So I basically have 3 modes at the ready.
      10-22-2018, 07:36 AM   #7
CarlosM4
Brazil
411
Drives: C63 AMG
How does that work? I have a current F06 M6, and when I press the memory preset it stays there. Does it work differently in the F90? For instance if I am the setting in M2, and I press twice does it go to the default Comfort everything?
      10-22-2018, 11:04 AM   #8
kdeleon
94
Drives: M5
I'm away from my car, so I'm not sure if it goes back to the last non-memorized configuration or all comfort (the later is the default when I start the engine so it is the majority of the time). But yes, if I activate M1 or M2 and then press that button again, it will take out the M1/M2 indicator on the dash and revert back to the non-memorized setting which is usually all comfort.
CarlosM4411.00
      11-03-2018, 08:46 AM   #9
CarlosM4
Brazil
411
Drives: C63 AMG
Yep you are right. If you press it all, it goes back to the last unmemorised setting. But I still left M1 in all Comfort, and M2 with All Sport+, MDM and 4WD Sport.
      11-05-2018, 12:05 PM   #10
shahin
170
Drives: 18 M5 FE,15 M6 GC, 12 M5,06 M5
Regards
Awd and awd sport you can have mdm and full traction off.
In rwd you can only have full traction off.
CarlosM4411.00
      11-07-2018, 03:06 PM   #11
tdlondon
Drives: 2019 X7 and 2020 X3 M40i
1985 BMW M635csi  [0.00]
2018 BMW M5  [0.00]
I agree. I have M2 as Carlos described and M1 in between, Engine sport, transmission on 2 bars, comfort suspension and sport+ steering. The all comfort option is the "default" with no M preset button engaged. At least in my car every time you restart it defaults to all Eco.
2018 BMW M5 Rhodonite Silver
1985 BMW M635csi Diamond Black
1994 Porsche 968 Amazon Green
1991 Acura NSX Red
1988 BMW M5 E28 (retired)
      11-07-2018, 09:57 PM   #12
fstezaws
91
Drives: 2020 911 S — 2022 X5 M50
4WD = DSC ON, DSC OFF. Can't do MDM in 4WD
4WDS = DSC ON, MDM, DSC OFF.
2WD = DSC OFF only.
This is how my car is enabled, US spec.
Another way of putting it:
DSC ON = 4WD, 4WDS
MDM = 4WDS only
DSC OFF = 4WD, 4WDS, 2WD
      11-08-2018, 08:12 PM   #13
kdeleon
94
Drives: M5
DSC ON = 4WD, 4WDS
MDM = 4WDS only
This is slightly off.
DSC On = 4WD only
4WD Sport is not available with traction fully on.
      11-13-2018, 07:40 AM   #14
TheRealOrosie
BMW Fan Boy
TheRealOrosie's Avatar
Drives: //M
My car too...always starts in default eco mode. All my M's with M buttons have always started in default settings.
