Belt Tensioner - What's Normal?
10-16-2018, 09:26 PM | #1 |
29
Rep 74
I apologize for being a newby on this. I've found picture of REALLY badly worn tensioners (with the belt about to fall off) but I'm just wondering where exactly the serpentine belt is supposed to ride. Is it OK if just near the edge of the pulley? I'm questioning a whining noise that the car makes at low RPM and noticed this looking pretty close to the edge of the pulley.
Thanks, M |
10-17-2018, 08:10 AM | #3 |
Hoonigan
6878
Rep 3,000
Drives: '09 328i, '98 Wrangler
That's normal. If the belt is coming off the edge of the pulley then it needs to be replaced.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
10-17-2018, 01:37 PM | #4 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Take the belt off and spin each pulley by hand.
Also the timing chain is a little noisey, don't get the sound mixed up
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
10-18-2018, 12:34 PM | #5 |
29
Rep 74
OK!
The tension pulley turned smoothly and stopped immediately if I flicked it. The other pulley to the right would spin for seconds. I'm not sure if that's OK. The steering pump turned pretty smooth, but make odd click/clack sounds as it changed direction when turned. The alternator was turned with a lot of drag on it. I guess that's all normal. |
10-18-2018, 02:43 PM | #6 | |
2214
Rep 2,219
Drives: '08 128i
Everything else is normal. You're just feeling the pump itself turn, alternator clutch, etc.
Efthreeoh17365.00 |
10-19-2018, 03:27 PM | #7 |
10
Rep 61
On my 60k miles E90, the dealer found the belt tensioner pulley is crooked during an inspection. I changed it myself. Easy DIY. When I inspected the old tensioner, I noticed the gap between the center plate and the housing is not uneven (one side is much closer than the other). Maybe you want to take a look of yours to see if you have the same issue.
