10-10-2018, 10:42 AM | #1 |
200
Rep 346
Oil pan gasket "seeping" oil
I had my 228i for an inspection at the dealer because factory warranty is about to run out. They said oil pan gasket is seeping oil but it is not bad enough to require replacement. Once seeping becomes leaking they have to fix it. I don't really care TBH because it is CPO and I'll definitely get rid of this thing before CPO runs out. But I'm still wondering if anyone has had the same experience? Dealer saying repair is not needed because it's is seeping not leaking? And also, what is really the difference?
10-10-2018, 12:07 PM | #2 | |
270
Rep 823
10-10-2018, 01:21 PM | #4 | |
200
Rep 346
I am kind of surprised though, in my experience VCG and OFHG are more susceptible to failure than OPG. |
10-11-2018, 11:01 PM | #5 |
88
Rep 509
Drives: 2016 435i
Very common issue on the E9X.
2016 435i MSport ZHP #85
10-12-2018, 07:25 AM | #6 |
E4 Mafia
308
Rep 408
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
seeping probably means the gasket is wet. it'll probably just make a mess after a long time.
the overall basic design of bmw's has been the same forever. to pull the pan and change the gasket you'd have to support the motor top side, then remove the subframe which has at a minimum the steering rack and control arms attached. not to mention the motor mount on it. they probably can't justify the work for the amount of seep.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
10-18-2018, 04:06 PM | #7 |
439
Rep 1,251
OP, you've documented with the dealer that the oil pan weeps oil. I think that that means that BMW NA is on the hook to fix it when the seep increases to an unacceptable level.
