BMW X5
      10-08-2018, 06:57 AM   #1
heinzena
119
Drives: 340xi M-Sport
Driving assistance plus vs Professional
Anyone know the difference between the Driving assistance plus option vs the driving assistance professional option (supposed to begin production in December)?
Thanks!
      10-08-2018, 10:00 AM   #2
iiAtlas
18
Drives: '18 X5, '18 718, '19 X5
Hey this is a big question for me too! All I can see from the order guide is that ZDY (Driving Assistance Professional Package) includes 5AR Extended Traffic Jam Assistant for limited access highways. Other than that the "5AU" code remains the same. I am curious if 5AR will be retro-fit-able? Or what exactly it means? Anyone with any knowledge would be greatly appreciated!
EDIT: Here's what I could gather so far! https://g05.bimmerpost.com/forums/sh....php?t=1542899
      10-08-2018, 12:32 PM   #3
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
I posted this in another thread as well:
"5AR Extended Traffic Jam Assistant for limited access highways" is the only difference between the two packages. 5AR will let you be "hands-off" for an unlimited amount of time if you are below either 45mph or 37mph (I forget which) on certain interstate and highways in the US.
The standard Traffic Jam Assistant only lets you take your hands off the wheel for 45-60 seconds at a time when under 37mph I believe.
So unless you spend a HUGE amount of time stuck in traffic on major freeways in the US and want to take your hands off the wheel, there isn't any difference between the 2 packages.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1
Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i
iiAtlas18.00
      12-27-2021, 07:51 PM   #4
emaniat
23
Drives: 2022 X5
Do both have the stop and go radar cruise control? Car in front of you stops you stop. Car in front of you starts then you start.
      12-27-2021, 09:53 PM   #5
Rondi
144
Drives: ‘22 BMW X6 40i, ‘14 BMW X3 35i
I have the dapp and I have used the Extended Traffic Jam Assistant for limited access highways under 40 mph once in a traffic jam here in Houston, it worked great
2022 X6 x40i MSport black sapphire / Cognac
aMIC31.00
xbimmers
