2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Fault code 30005
      10-05-2018, 03:49 AM   #1
Nikkigphx
JustDAutoService
Drives: 2004 325i
Unhappy Fault code 30005
Hi everyone and anyone who is able to help me. I'm a newbie. I can't get my driver's side window to roll up. First none of them would do anything. Then I plugged in my scanner and all of them except drivers side. I get this code 30005 anti trap. Can someone anyone please help me. It's a 2012 528i xdrive. Thank you
      10-05-2018, 05:14 PM   #2
jimk
jimk's Avatar
104
Drives: 2018 M550i
This may help:
https://f10.5post.com/forums/showpos...06&postcount=3
      10-06-2018, 01:18 AM   #3
ezaircon4jc
ezaircon4jc's Avatar
Drives: 2019 540i M Sport
This??
https://5series.net/forums/diy-do-yo...p-reset-25812/
      10-06-2018, 01:02 PM   #4
Nikkigphx
JustDAutoService
Drives: 2004 325i
The drivers window is denormalized. Will not reinitialize. It will roll down not back up. Regulator has been removed and checked. Window motor only operates when you push switch in open position. Only hear a click from relay when you put the switch in the close position. Error codes are anti trap mechanism malfunction.
Nikkigphx[/SIZE]
      10-06-2018, 04:34 PM   #5
ezaircon4jc
So are you pulling the window up manually?
      10-06-2018, 09:16 PM   #6
Nikkigphx
JustDAutoService
Drives: 2004 325i
I have to take the glass off the regulator, disconnect the motor from the regulator, so the regulator will slide freely then reinstall the glass and slide the glass all the way closed. Then reinstall the motor so it will stay in place.
Nikkigphx[/SIZE]
      10-06-2018, 10:05 PM   #7
ezaircon4jc
Sounds like a regulator motor problem. Are you absolutely sure the motor is fine? I don't know where the "trap" function lives, but it sounds to me like the motor is at fault. Do you have access to the diagnostic tree?
      10-07-2018, 02:14 AM   #8
Nikkigphx
JustDAutoService
Drives: 2004 325i
Starting to question the FRM
Both front and rear on the left side use the same motor. I stopped them with know change. I used a Maxicom Mk808 and had the same problem. It came up with [IMG]undefined[/IMG]
Nikkigphx[/SIZE]
      10-09-2018, 05:31 PM   #9
ezaircon4jc
Any news? Maybe a trip to the dealer is in order?
      10-13-2018, 07:35 PM   #10
Nikkigphx
JustDAutoService
Drives: 2004 325i
Know and I really don't want to go to the dealer so they can just plug in there scanner and tell me what I already know. Then charge for that then charge me again for fixing it. But that's gonna be the solution because I can't figure it out. Thank you
Nikkigphx[/SIZE]
      10-14-2018, 09:26 AM   #11
The TRG
Drives: 2016 340ix Black Sapphire
Just a random thought here... and I apologize if this doesn't work in theory: couldn't you pull the motor or regulator from the other side and test them as individuals? ie: passenger reg with driver motor, and see if it works. Again, just my nature to test with what I've got... but if the parts aren't interchangeable from pass to driver then I'll sit down and be quiet.
      10-14-2018, 04:53 PM   #12
Nikkigphx
JustDAutoService
Drives: 2004 325i
yeah tried that already thank you appreciate it. still didn't work
Nikkigphx[/SIZE]
5post
