09-27-2018, 09:45 PM | #1 |
BimmerPost Supporting Vendor
3467
Rep 6,683
► JRZ RS Coilover Package Group Buy - Hosted by APEX
This JRZ deal has ended, but we just launched another round! For more information regarding round 2 of our JRZ Group Buy, visit the link here here
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-19-2018 at 03:58 PM.. |
10-03-2018, 01:51 PM | #2 |
3467
Rep 6,683
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-19-2018 at 03:55 PM.. |
10-22-2018, 03:16 PM | #3 |
3467
Rep 6,683
”What makes JRZ so special, and which damper from their RS Line is best for me?” Since APEX first released these custom suspension packages built around JRZ RS dampers, these have been the two most prominent questions proposed to our Product Experts. This is usually followed up with, “what spring rates, rear shock mounts and other accessories should I choose”. As car enthusiasts we all share a passion for a specific marque, but often times that is where common ground ends. Even within our tight knit team of car enthusiasts here at APEX, it is clear that these cars are enjoyed in different ways, and we each have different goals, opinions, and expectations on how a car should or shouldn't be modified. This sentiment has stuck with APEX over the last 10+ years, and has been a driving force behind offering the community a wide array of wheel fitments that specifically met the diverse performance and budgetary needs of our customers. Forcing limited “cookie cutter” wheel fitments onto a diverse audience meant compromises would have to be made along the way, and that was quickly something that APEX navigated away from. In more recent years, this theme continues with our suspension solutions. APEX hand picked race proven suspension components from three industry leading manufactures to create fully customizable coilover packages, and with JRZ’s 60+ years of experience in development and production of Motorsport grade dampers, we knew the JRZ RS line would provide our customers with the right foundation for each configured kit. Back to the Basics Before we dive into the details and differences of JRZ RS dampers available to us, let's review some basic suspension principles at a high level. In order to make an informed purchase decision, it is important to have a general understanding of the different components that make up a coilover, as well as the job of supporting suspension components. This is best explained by Motorsport guru Jay O’connell featured in the SAFEisFAST series, and we’ve compiled cliff notes below. 1. Springs
2. Dampers (Shock absorbers)
3. Damper Adjustments
4. Bump Stops
5. Anti-roll Bar
Moving in the Right Direction - JRZ RS Dampers Quite often aftermarket suspensions targeted at car enthusiasts are not actually improving the handling capabilities of your vehicle. There’s never a shortage of “lower grade” dampers or coilover packages on the market disguised in enticing packaging with fancy marketing, so it is important to know the genetic makeup of what you are buying. When I ask customers to identify some of the key features they would like out of their new suspension, height adjustability is commonly the first answer. The ability to adjust vehicle ride height is desirable for a few reasons beyond getting rid of that unsightly wheel gap, however this is a standard feature of any coilover design and you owe it to yourself to set the bar much higher. Premium grade coilovers are designed around quality dampers built for a specific operating range of spring rates, and these two components are co-developed to ensure maximum control over the vehicle's movement while it negotiates uneven road/track surfaces. The end goal is to reduce drama transmitted to the chassis, prevent loss of tire traction / maximize grip, and to keep things consistent and predictable for the driver. This is not to be confused with suspension that is overly stiff - a common misconception amongst car enthusiasts. Needless to say, not all coilover packages are created equal. The JRZ RS-Line is hand built on the same production line as their ($8,000+) red motorsport-grade dampers. The build quality and attention to detail is second to none, and this is apparent from the moment you open the box and begin to handle the components. Every piece is anodized, leaving no uncoated corrosion-prone surfaces. Because the dampers are made by hand, each and every set is reviewed by a craftsman/craftswoman to ensure consistent quality, and personally signed off before making its way to you.
The Golden Question - To What Degree do you Want to Tune Your Suspension? Through conversing with a broad spectrum of customers, this is the major fork in the road. We can all agree that we would like our aftermarket dampers to significantly improve the handling characteristics of our vehicle, but to what degree are you willing and able to fine tune your dampers to optimize results given your vehicle setup, intended use, driving style etc.? Since dampers are the centerpiece to any high performing suspension package, it is important lay everything out on the table before making a decision. What are your long term goals for the car? Do you desire to compete in a form of class racing or time trials where the governing body imposes restrictions and guidelines? These are things to consider to ensure you are satisfied with your purchase in the long run. I want to be clear that all JRZ RS dampers are very capable, and with the right supporting suspension components and chassis alignment they will dramatically improve the drivers ability to control the vehicle. The question is, how involved do you want to be? As we move through the different RS dampers available, each increases your ability to fine tune the suspension in a more granular way. The ability to externally modify damping characteristics is a desirable feature, particularly for those in continuous pursuit of improving lap times or beating out the competition. These enthusiasts and racers alike will go through the effort of adjusting rebound, compression and even external reservoir nitrogen pressure to compensate for tire wear, variations in track surfaces leading to poor or inconsistent levels of grip, and even in some instances driver errors. RS ONE - Single Adjustable Dampers The RS ONE is a single adjustable damper with 21 precise clicks of adjustment, and valving capable of handling a broad range of spring rates. Through the twist of one knob, JRZ strikes a balance of adjusting both rebound and compression together. Moving between comfortable street use, aggressive track mode, or anything in between has never been easier. The RS ONE design minimizes complexity, while still providing a significant increase in performance. If you are not the type of enthusiast to explore different spring rates, alignment settings or other chassis setup features on a continuous basis, and prefer to get a capable suspension as close to “set it and forget it” as possible, the RS ONE dampers are the perfect solution. RS TWO - Double Adjustable Dampers The RS TWO is a double adjustable non-remote damper which offers independent compression and rebound adjustment. Having both compression and rebound adjustability independent from one another allows users to make more precise inputs to find the balance they are looking for. The RS TWO has 21 precise clicks of rebound adjustment controlled by a knob positioned at the top of the strut, and 14 precise clicks of compression controlled by a knob positioned at the bottom of the strut. Whether you are interested in getting slightly more involved in the suspension tuning process from the get go, or ensuring you have the option to get more granular with suspension adjustments as you become a more experienced driver, the RS TWO has you covered without the added complexity of external reservoirs. RS PRO - Double Adjustable Dampers The RS PRO is a double adjustable damper which incorporates championship winning external reservoirs for maximum control. Like the RS TWO, compression and rebound adjustments are made independently from one another, allowing enthusiasts to calibrate their suspension from compliant street mode to taking the checkered flag. The RS PRO has 21 precise clicks of rebound adjustment controlled by a knob positioned at the top of the strut, and 14 precise clicks of compression controlled by a knob located on the external reservoir. If you are a suspension geek, serious track junky or competitive racer, the RS PRO is an extremely effective weapon. These dampers and external reservoirs are aimed at enthusiasts who will take the time to explore and document a variety of spring rates, alignment settings and other chassis setup features all in the name of pushing their cars and their skills to the limits. The value added from the external reservoirs is listed in the "remote reservoir" section below. RS PRO 3 - Triple Adjustable Dampers The RS PRO 3 is JRZ’s flagship triple adjustable damper for the RS line, which incorporates championship winning external reservoirs for maximum control. The RS PRO 3 has 21 precise clicks of rebound adjustment controlled by a knob positioned at the top of the strut. It also has 14 precise clicks of high speed compression and 8 precise clicks of low speed compression, both controlled by knobs located on the external reservoir. Independently tuning high and low speed compression allows track junkies and competitive racers alike to get the absolute most out of their suspension. Double adjustable suspensions do not allow users to isolate and control high and low speed compression damping. Low speed compression controls the speed at which the suspension compresses while the car negotiates small bumps, and prevents wallowing. High speed compression controls the speed at which the the suspension compresses while the car negotiates quick or abrupt movements, like hopping berms or drastic changes in the road surface. Although more adjustments can add a level of complexity to the end user, it is important to note that you can set low speed compression to full stiff, and the damper will now behave the same as the RS PRO double adjustable suspension. As you develop the car over time and become more familiar with fine tuning the suspension, you can then make adjustments to the low speed compression to find the perfect balance for your specific track surface(s). The RS PRO 3 is the ticket for hard core track enthusiast and competitive racers looking for any and every available edge over the competition. The value added from the external reservoirs is listed below. Remote Reservoirs - Applicable to RS PRO & RS PRO 3 External reservoirs significantly increase performance capabilities by providing more fluid displacement and increased cooling capacity. Track enthusiasts and racers push their cars to the limits, and external reservoirs are one of the key ingredients to consistent damping performance from the starting line to the checkered flag. The nitrogen pressure within the external reservoir can also be adjusted between 150 - 350 PSI; a key feature for track and race enthusiasts looking to fine tune their suspension to the highest degree. Lines to each reservoir are long enough to comfortably mount them under the hood and trunk in a cool location that’s easily accessible. For a painless installation, all PRO kits come with front quick disconnect lines. Some enthusiasts within the BMW community have years of experience and seat time under their belt, and with good information available to them, they are able to digest it with relative ease and make good purchase decisions. For many others it can be information overload, and therefore we recommend having a one on one consultation with an APEX Product Specialist to further discuss personal goals, expectations and budget. We may not have all the answers, but working closely with JRZ, Ground Control and Hyperco allows our staff to deliver top notch customer support, pre and post purchase. Keep in mind, configuring a suspension package and installing it on your vehicle is only half the battle. To get the most out of your new purchase, you’ll want to know that experts are there to support your efforts along the way. - Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
10-25-2018, 03:03 PM | #4 |
1417
Rep 2,650
Group Buy Update
We are down to the last four days of this deal. We’ve made some progress so far, but it’s crunch time and we need everyone’s participation to make this deal a success. We know there is a lot of interest within the enthusiast community for premium quality dampers, and that availability, lack of technical information and/or pricing has held many of you back from taking the plunge. By taking the price barrier out of the equation and offering customizable packages, we are hoping more enthusiasts are able to make an educated suspension purchase which meets and surpasses expectations and long term goals for the car. You'll never look back. It is totally still feasible to reach one of the top tiers offering massive discounts, but we need everyone to return to the deal page to confirm their official pledge. We are accepting pledges up until October 29th at midnight. We ran a similar deal for the E36/E46/Z community last month, and many joined within the last couple of days of the deal allowing us to successfully reach the top discount tier. It can be done! Whether you are planning to install aftermarket suspension on your car for the first time or replacing another brand that failed to provide you with the performance you were looking for, this is an extremely rare opportunity to acquire a premium grade coilover package at prices that are simply unheard of. Our suspension experts are available for one-on-one consultations to ensure you get the most out of this opportunity.
10-29-2018, 03:56 PM | #5 |
1417
Rep 2,650
Our previous E36/E46 JRZ Group Buy was a success last month, and a production run for those lucky recipients is currently underway. Below you will find some dramatic shots of the raw strut bodies, staged to receive their protective coatings. It is said that mastering a craft has less to do with the end product, and more to do with the process. We completely agree as these are truly a work of art in raw form courtesy of our technical partners in the Netherlands.
- Ryan
12-07-2018, 02:13 PM | #6 |
1417
Rep 2,650
Hi Everyone,
It has been a few weeks since the JRZ Suspension Group Buy ended, and we wanted to update all of you on the progress being made. Dampers are on schedule, and below you will find some dramatic shots of the raw strut bodies staged to receive their protective coatings. It is said that mastering a craft has less to do with the end product, and more to do with the process. We completely agree as these are truly a work of art in raw form - courtesy of our technical partners in the Netherlands. We look forward to sharing more updates with you, and from everyone at APEX we wish you Happy Holidays. - Team APEX
