09-19-2018, 05:03 PM | #1 |
Rep 17
xdrive modes vs mdm vs dsc
After few days with my F90 I'm still confused about modes and their relation to each other - which is precedent?
So I can press DSC button or hold it. I can change m xdrive config (4wd, 4wd sport, rwd). I can mix those two, sometimes one changes other. Dashboard says mdm... I can't make real tests because of break in time so can anyone explain hierarchy of different modes and consequences? |
09-19-2018, 06:43 PM | #2 |
2462
Rep 3,803
When you start the car = Full DSC = No Fun
Short Press of button = MDM = Fun Long hold of button = NO SAFETY NETS = Tickets and Smiles As far as power to the wheels AWD, is standard AWD Sport AWD significantly less power to the front wheels. 2WD is just what it says. |
09-20-2018, 08:47 AM | #3 |
Rep 17
Thanks
As I understand: - it is possible to play with dsc button (with 3 modes: on, mdm, off) while having independent option to choose if i want: awd or awd sport - but if I want rwd than i must switch off dsc So question is: when I should use one of 5 combinations: - awd sport + dsc on - awd sport + mdm - awd sport + dsc off - awd + mdm - awd + dsc off In other words: what are scenarios when each combination is optimal? lame combination: awd + dsc on is obvoius pro combination: rwd + dsc off is also obvious Last edited by slaweksss; 09-20-2018 at 08:52 AM.. |
09-26-2018, 06:50 AM | #6 |
292
Rep 605
The most obvious thing here is the answer to the question you initially posted. If you're looking to step the rear end out in daily driving, I hope I don't live near you.
09-26-2018, 06:47 PM | #9 |
325
Rep 519
09-28-2018, 03:47 PM | #10 |
292
Rep 605
Nope, just adding my 2 cents. The comments following sheriff suggest that I somehow should have known where he's located, and then went on to condescendingly describe his location with respect to mine. Keep it classy, Poland.
09-28-2018, 04:25 PM | #11 |
94
Rep 249
In all fairness, slaweksss' profile does say their location is Poland.
10-01-2018, 09:32 AM | #16 |
292
Rep 605
You didn't like the answers you got when you asked a question with very obvious answers. Unfortunately, there's no cheat-code secret combination of settings that miraculously makes the car better. Then you respond with an insult, then more insults. You're a troll who just didn't like my response. Grow up man.
10-01-2018, 03:05 PM | #18 |
4065
Rep 5,231
Gents, PM each other. No one gives a ...
