Looking to get some new wheels - BBS RGR
07-01-2008, 07:06 PM | #1 |
8
Rep 113
I have a friend that has some BBS RGR's off of his M3. The specs are this:
19 x 8.5 BBS RGR 19 x 10 BBS RGR TIRES: 245/35ZR19 Bridgestone Potenza RE050A Pole Position tires 275/30ZR19 Bridgestone Potenza RE050A Pole Position tires Will I have any issues getting them to fit my E90? This tire and wheel stuff is foreign to me. Any help is appreciated. Also, can I add the TPMS to these? If so, how? Thanks. |
07-01-2008, 07:14 PM | #2 |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
Fitment will all depend on the ETs. Since they are off an M3 (E46?) I'm guessing you'll need spacers for the front, which are usually around ET 44. the rear is probably going to be an issue, because I believe M3 ETs in the rear are something like 22 or 23. With a 10" wheel and ET 22, you'll probably be rubbing.
But we can't say for sure unless we know the exact ETs on the wheels. But I do like the looks of the RGR!
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
07-01-2008, 07:29 PM | #3 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Well, I looked up what BBS recommends for a E46 M3 and their specs for the RGR are 19x8.5 +35 and 19x10 +25. At those ETs, the fronts should be fine, however the rears may be a few MM of offset too aggressive. I've seen members install our 9.5 +22 on their E90s with 265 tires, but this 19x10 +25 will protrude 3mm more toward the fender and you'll be using an even larger tire. It's safe to say you'll probably need some camber or some fender rolling to get this to work for you.
VMR|Wheels | 714.442.7916 |
07-02-2008, 01:26 AM | #4 | |
112
Rep 2,433
