N52 Magnaflow muffler and ?
09-15-2018, 04:26 PM | #1 |
218
Rep 576
Hey, I'm new to the forum and really, I'm new to BMWs as well. I used to build trucks instead. Anyway, I have a 2006 325i and I put the Magnaflow 12148 muffler on it. It turns out it sounds nice, but is not as loud as I'd like it. I'm in NC so I cant do a muffler delete (illegal), and I'm 17 so I cant pay for the $1,000 PE. I've seen resonator deletes replaced with X pipe, secondary cat deletes or catless midpipes, and catless downpipes. Which would be the best option to take the sound from the magnaflow muffler and basically amplify it? I have done plenty of research but I just can't find exactly what I'm looking for. I'm open to other options as well. I'm also a fan of the pops and crackles on deceleration. Thanks in advance!
(Attached is a pic of my car) |
09-17-2018, 01:26 PM | #2 |
Basic Bimmer
518
Rep 935
Drives: E92 328i 6MT ///M
Hey man, welcome to the forum.
First of all, I really suggest you try searching. Search from within this subforum (N/A engines) near the top-right of the screen for more specific results. This topic has been covered a ton here lately. Or just scroll through a few pages of threads and you'll see what I mean. To quickly advise, do what is referred to as a "secondary cat delete." You can either have a muffler shop just cut them out and weld in pipes, or you can buy fancy pipes then cut your exhaust in two spots and install them yourself. Choice is up to you. It's the mod you want. Trust me. aFe and SuperSprint make the aftermarket pipes. But a muffler shop will be easier and cheaper.
Black Sapphire 328i ///M Sport Coupé Save the Manuals! |
09-17-2018, 04:18 PM | #3 |
218
Rep 576
atmosphericM, thanks for the response. I actually went this morning and got my secondaries taken out and I do think its what I wanted as it makes my car a little louder as a whole and gives it a deeper idle tone. Eventually I may do high flow catted down pipes since the secondary cats didn't add any pops/ gurgles but over all I'm happy with it.
09-17-2018, 04:23 PM | #4 |
996
Rep 2,287
You joined the E90 group at a very good time. If you pay attention, you can reap the rewords from several generous people who have shared their efforts to the community.
There are several very low cost modifications you can do to really improve your cars performance. In the order of cost, cheapest to most expensive; 3 stage intake manifold swap and free 330 tunes made available by BimmerLabs. More HP, torque and meaner intake sounds. Essentially turns you motor into a 330. 255HP at the crank vs your current 215. If you have ZF automatic, upgrade to the 330 tune. It's free and manages the extra torque from the 3 stage manifold better. BimmerLabs also has a tune that activates you active gear display in D and sport. MILVs add intake valve lift but require a custom tune to work correctly. Headers and tune, if you don't worry about vehicle inspections. Can't arrange these by cost; Lesser gains can be found with a noisy exhaust, plenty of threads and opinions available on this topic. Intakes/filters and such, same deal plenty of opinions. Swapping rear differentials, we have a long post covering this topic. Automatics have taller gears in the diff. Some love it. Dig through the forums and have fun |
Biginboca3763.50 eddieboy51046.00 |
09-17-2018, 05:21 PM | #5 |
218
Rep 576
rjahl, thanks for the welcoming. I'll have to look into the tune, it sounds like a good mod. Ive been looking at a couple intakes and i know they give a few HP but do they change the sound of your car? Ive heard people say after installing an intake their car has a different tone but i cant justify why that is.
Noir883.00 |
09-17-2018, 05:41 PM | #6 | |
883
Rep 1,413
Anyways, welcome! As stated above, great timing!
See you, space cowboy.
Supercharged |
09-17-2018, 08:27 PM | #7 |
218
Rep 576
Noir, Im not sure how to quote through the mobile app yet so bare with me. Anyway, I've heard of the euro intake and I've heard all good things except that they have a high price tag. So, I've been looking at cheaper ones like an AFE or Injen thats less than $450 or so. But, I have also seen people do a charcoal filter delete or a K&N drop in filter (supposed to increase flow by 60%) so before I do anything, I'll be sure to use the search bar first this time! I'm also interested in the air scoops from ECS Tuning so if any of you have experience with those, I'm all ears!
Thanks again for all of the greetings/ welcomings! |
09-17-2018, 09:49 PM | #8 | |
883
Rep 1,413
Man. you're a week too late, I let all the stuff I said up there, go for less than that. Would've loved to have helped you. Them air scoops definitely get air in there... but not hyped up to what they try to be. Aesthetically pleasing, sure. But even so, wouldnt spend the coin, in my opinion... Theres a thread somewhere in here that goes a bit more into detail.
Supercharged |
09-18-2018, 11:33 AM | #10 |
Basic Bimmer
518
Rep 935
If you drive hard you will get more of the cracks and pops. I suppose it's also possible that the OE center muffler (often referred to as a resonator) subdues the pops a bunch - but I'd be surprised if that's the case. I have stock headers (with cats), stock secondary cats, and a PE muffler/mid-pipe, and I get a fair bit of pops and cracks. The only real difference is that the PE deletes the center muffler. Who knows?
Also, if you're on a tight budget, you can't beat simply deleting the charcoal filter and replacing the stock hose with a silicone one. For the $60 you'll get around 10 hp. If you do want to go with another intake box, the most proven ones are both expensive (euro or aFe Stage 2 SEALED), unless you can find them used. I paid very little for my euro intake. Personally, I'd skip the scoops. In my eyes, their only redeeming trait is that they look kinda cool. To each his own, though.
Black Sapphire 328i ///M Sport Coupé Save the Manuals! Last edited by atmosphericM; 09-18-2018 at 11:44 AM.. |
Biginboca3763.50 |
09-18-2018, 05:40 PM | #11 | |
996
Rep 2,287
By far, the best performance impact you can make on your 325 is the three stage manifold swap and Tune. You can easily research the manifold, there must by 1,000,000 posts about them. The tune Bummerlabs provides simply let's your car use the manifold correctly via a BMW tune. No jacked up timing or fuel mixtures. It's a real 330 tune from BMW modified to run in you 325. If you want to take thing further, the three stage manifold will only enhance the other mods. Enjoy the journey. |
Biginboca3763.50 |
09-16-2019, 11:53 AM | #12 | |
69
Rep 176
09-16-2019, 01:47 PM | #13 | ||
996
Rep 2,287
I can say that value wise, the 3IM can't be beat. Maybe $300 for a used manifold , 3 hours of your time, A free tune from Bimmerlabs should be worth 40HP at the crank for a 325. Best yet, it will not set off any alarms at the smog station. If you really want to kick it up with your Auto, pretty sure you have a ZF, I can swing something by Hass and set you up with something I've written to spice those up. I good tranny tune makes a huge difference to the fun factor. Those slow and sloppy 2-3 shifts made me puke. |
F30NFifty568.50 |
09-17-2019, 12:13 AM | #14 |
3973
Rep 7,215
Headers *might* make more power (by themselves, I doubt that), but the 3 stage is a far easier installation, uses all OEM parts, causes no errors and will pass emissions in 50 states.
Seems like a no brainier to me. Of course, the combination of headers and the manifold will make even more power, but personally I never thought it was worth the trouble - and I can bend the N52 DME to my will as I please. |
09-17-2019, 10:31 AM | #15 | |
Hoonigan
6870
Rep 3,000
Drives: '09 328i, '98 Wrangler
hass I have the N51, so I already have the 3 stage. Which tune would be best? From research it seems the only one I can find is the AA tune. Car is stock besides a Euro intake box and eventually a Magnaflow muffler.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
09-18-2019, 07:38 AM | #16 | |
69
Rep 176
or any power loss in low end power ? Removing my secondaries on Friday |
10-02-2019, 10:43 PM | #17 | ||
218
Rep 576
10-04-2019, 10:54 AM | #18 | |
203
Rep 437
10-07-2019, 09:59 AM | #19 | |
69
Rep 176
10-14-2019, 08:03 AM | #20 | |
Rep 11
10-14-2019, 09:57 AM | #21 | ||
996
Rep 2,287
Only hick-up I have is the kombi in some of the older cars does not like to display the active gear in D or Sport mode. That's a simple switch in the Tune, either you can turn it in or you can't. The only remedy is to swap the Kombi with a newer unit. |
10-16-2019, 09:17 AM | #22 | |
Rep 11
Tags |
325i, exhaust, n52, n52 exhaust |
