BPC MAFless tune
09-13-2018, 08:28 PM | #1 |
Rep 6
BPC MAFless tune
My car is a 6MT with AA headers, BPC tune, PE, and charcoal delete and I will be adding 3IM pretty soon. I've been seeing a few posts about BPC's Alpha N tune lately and was wondering if anybody running it could give me some feedback on it. I would add it along with my 3IM retune.
E92 6MT XDrive - AA Headers, PE, BPC Tune, Charcoal Delete
ECS Drilled+Slotted, Hawk HPS, Conti ExtremeContacts |
09-13-2018, 10:50 PM | #2 | |
2465
Rep 9,004
Biginboca3763.50 |
09-14-2018, 01:42 PM | #3 |
179
Rep 601
09-14-2018, 02:00 PM | #4 | |
2465
Rep 9,004
I know Hassmachine says that there was an increase in response and torque, but I don't personally remember that. |
N52UNED179.00 |
09-14-2018, 02:14 PM | #5 |
3973
Rep 7,215
I think its worth it if you dont have headers. Its a cheap and easy mod - but I still dont think it works well with headers (yet) until the O2 sensor tuning can be addressed. The adaptations will go wacky after about a week.
FWIW this is the same reason ESS couldn't make their supercharger work with headers (and also because at first they just cut the MAF wires and ran it in limp mode, lol). |
09-14-2018, 02:56 PM | #6 | |
179
Rep 601
I've been trying to dig up as much info as I can since you mentioned it on my Mod question thread. The only thing I've really found is that it lessens your MPG and BPC suggests not to do the MAF delete if that's a concern. Do you know the power gains vs the lessened fuel economy? Personally I'm fine with more power and less MPG (which really goes hand and hand anyway) ... I'd just hate to lose like 10 mpg for a small gain. |
09-14-2018, 03:12 PM | #7 |
3973
Rep 7,215
No, with headers it just doesnt work. The fuel trims get out of wack and the car doesnt run right, because it relies on O2 sensor feedback - which is now wrong because the sensors arent in their original location (yes, its that sensitive).
You shouldnt get lower fuel economy, at least not with my version. My long term MPG is 23.5, and on all highway I'll get 35. The N52 was designed to run with no MAF, that is the mode I use, it runs like it's factory stock because it is (mostly). |
N52UNED179.00 |
09-15-2018, 07:06 AM | #8 | |
619
Rep 1,402
If I have a 'log' exhaust manifold basically all ports about 3" into a larger log with a rear bottom mount turbo- If I put the O2 sensors on top of the manifold in the log at cylinder #2 and #5 in similar position to stock, Do you think that the MAF-less tune and O2 sensors would work OK? |
09-15-2018, 10:01 AM | #9 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Can confirm lol I'm running headers with a 130i-based MAF delete tune (using the Euro IAT)
After a few hundred miles of both city and highway, the adaptations handled a bit of the weird running but it still isn't perfect. City MPG is lower than it was, but highway actually seems real good. Got a little bit more mileage than I usually do when bouncing between Daytona and Orlando.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
N52UNED179.00 |
09-15-2018, 10:13 AM | #10 | |
3973
Rep 7,215
Might be better off putting one or both sensors in the collector. I'm not sure but I think you can configure the DME to use only one O2 sensor. Did BPCs turbo car use a MAF? |
09-15-2018, 12:09 PM | #11 |
253
Rep 775
You have any idea as to which values would need to be adjusted? As I mentioned in the other thread, might as well study the S54 tunes a bit. O2 location is quite different between US and Euro
09-15-2018, 03:35 PM | #12 |
619
Rep 1,402
If I place the O2 sensors at cylinders 3 and 5 then the O2 sensors would get readings from cylinders 1+2+3 and 6+5. One from 3 cylinders and the other from 2 cylinders,
better than just 1 cylinder. The connection pipe for the turbo would probably be between 4+5 or at 5 cylinder on the bottom. IDK what BPC did. I will have to look closer to their build of their turbo N52. Last edited by CobraMarty; 09-15-2018 at 05:07 PM.. |
09-15-2018, 09:03 PM | #13 |
3973
Rep 7,215
yeah, I know which maps they are - those euro headers look a lot like a typical N52 header, and might be a good clue. The trick is really finding which is the 'euro' map on the S54 Z4M - should be able to do that easily enough though.
09-16-2018, 06:08 AM | #14 | |
Save the manuals!
6019
Rep 6,749
7837920 — E36/7 EOBD — ZB 7837919** 7837922 — E36/7 SA861 — ZB 7837921** Maybe that helps.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
09-16-2018, 06:58 AM | #15 | |
253
Rep 775
Z4MR USA - 7840453 Z4MR ECE - 7840455 |
09-16-2018, 09:21 AM | #16 |
3973
Rep 7,215
Yeah, MSS54 is quite different, its much older architecture. It doesnt have widebands, for example. We're specifically talking about the Z4M, which uses MSS70 - its like MSV70's twin brother (and a close cousin of MSx80). About 95% of the maps are the same, which is useful..
09-17-2018, 09:05 AM | #19 |
2465
Rep 9,004
09-17-2018, 09:07 AM | #20 |
3973
Rep 7,215
my MAF delete tune does NOT run in open loop. I specifically do not call it Alpha-N because it's not Alpha-N at all.
desertman1232213.50 |
09-17-2018, 09:12 AM | #21 |
883
Rep 1,413
Sadly, I was a dunce and forgot my IAT the day I drove down. I guess Bob tweaked the stage 2 to match the title... From a buttdyno when I found/installed the sensor and reflashed, I cant really say there was much difference, in my opinion. The noted "not so smooth idle," was present. Im sure the couple extra ponies are there... but to reverse someones header setup for it to run like a top, I wouldn't say its worth it. Unless its like Bob said, track usage above all else. Even then, I am not too privy as to how the open loop map works to benefit the car in that environment.
See you, space cowboy.
Supercharged |
