2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing How about 18' wheel 245 tires all around?
      09-13-2018, 03:32 AM   #1
beevanka
beevanka's Avatar
Drives: 2017 M2 6MT
Hi Guys.
Do you think it's a good idea to have 18' wheels 245 tires all around?
I saw someone has 245 all around, so I was thinking to buy another set of OEM 18' wheels and put the back wheels in the front, with PPS tires?
Not sure if it's good
      09-13-2018, 09:42 AM   #2
TajoMan
TajoMan's Avatar
174
Drives: M240 xdrive, X3M40i
I don't think OEM rear wheel will fit in front. (I believe it has 52mm offset)
you need a rim with very specific offset to put 245 in front.
      09-13-2018, 01:39 PM   #3
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Originally Posted by beevanka View Post
Hi Guys.
245 on 17x8 et40 works... et42 would be the ideal...
      09-15-2018, 01:27 PM   #4
beevanka
beevanka's Avatar
Drives: 2017 M2 6MT
Hi Guys.
Saw someone running BBS CH-R with 245/35/18 on all four wheels on Instagram
Hi Guys.
      09-15-2018, 02:29 PM   #5
dradernh
dradernh's Avatar
4348
Drives: 2017 M240i
Given the reality of changing wheel and tires sizes generally, and especially in the rear of these 2 Series cars, I would suggest being prepared to experiment, if only on paper, with wheel widths, tire widths, offsets, and cambers, front and rear.
In my experience, the fastest and cheapest way is to engage qualified shops and/or vendors to help you navigate your way through the maze. I say this as someone who over the years and across many BMWs has bought multiple sets that were supposed to fit, should have fit, and I was just sure would fit. My takeaway from those missteps is this: thorough research is your friend.
Oh, and don't forget fender-rolling as another tool that can help you get what you want.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
      09-18-2018, 01:17 PM   #6
ralawren
Drives: 2015 228i MSport w/Trk Pkg
With the correct offset or spacers they should fit. I ran 245/35/18 on stock 18/7.5" wheels. It was an error but the 245's fit fine. I plan on using them for track days. 18x8, offset 42 on all 4 wheels. Check this site to see how well they will fit.
https://www.willtheyfit.com/
      10-21-2018, 03:10 PM   #7
skievl23
Drives: 228ix Msport THP
225/45/18 ET30 does NOT work. choose a different offset or they will rub, as mine did
      10-29-2018, 12:32 PM   #8
ralawren
UPDATE - just ran 245/35/19 Squared at track
UPDATE: I just ran a square set up at the driving school yesterday and everything was fine. I purchased 18x8" 42 offset wheels and ran 245/35/18 Michelin PSS. Everything worked fine, no rubbing and the square set up had less understeer than the staggered. I do not recommend the PSS for the track, but am using because they were my original street tires and didn't want to throw them away. When these are gone I am replacing them with a Street/Track performance tire from Hankook, Toyo or Bridgestone.
      10-30-2018, 10:57 AM   #9
Maynard
Drives: 228iX & M2C
Thx for the info, considering this myself for track set. Was that w/ spacers in front, or just by themselves?
      11-05-2018, 09:40 AM   #10
ralawren
No spacers with 18x8 and 42 offset. No clearance issues at all.
Maynard3833.00
      11-05-2018, 12:29 PM   #11
GregoryG
Drives: '14 M235i 6MT - EB II
I'm about to do the same thing. Just purchased two 18x8 436M rears from a staggered set and going with square 245/35R18 all around. I realize there'll be clearance issues in the front due to the offset so I'm also getting 12 and 15mm spacers to account for that.
      11-06-2018, 05:19 PM   #12
esoulliard
Drives: 2015 Mineral Grey M235i 6MT
FWIW, I also run a 245/35/18 square setup. I've done multiple track days with no issues. My offset is 40 all around. It helped reduce understeer - the car feels very neutral now.
      11-26-2018, 01:27 PM   #13
hwntime
hwntime's Avatar
270
Drives: F22 Raptor
Are you 18x8 with the +40? That's what I'm on and thinking about going 245 up front too.
      11-26-2018, 02:26 PM   #14
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
MPss in 245 is like a 235 in other brands tires.
You will probably rub in the front, depnds on the offset but a pair of spacers will take care of that.
Also if you are dropped, it wont fit in the rear probably unless you drop the sidewall down.
On stock ride height, i was able to fit 18x40x235 Nitto 01s which is a wide tire without much rubbing.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
Maynard3833.00
      12-16-2018, 03:29 PM   #15
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Bryan - When I had my 235i, for track days I ran a square setup on 17x8" wheels with the 245/40ZR-17 Hankook R-S3 (Version 2) SL tires. I don't recall the offset, but it was probable an ET40 all around. No issues with running or clearance with this setup. This was a great setup for several reasons. First, I could swaps wheels and tires front to rear. Also, the Hankooks have a super stiff sidewall, so they don't eat tires like the MPSS. Second, this setup saves about 7-8 pound per wheel. Plus, 17 inch tires are cheaper than 18s. To counter act the inherent front end push of the 235i, I ran the fronts with 2lb more pressure than the rears. I'll see if I can find a post I did several years ago with all of the details. Note - Hankook now has the R-S4 which is an update to the R-S3. I run the R-4s on my M2 and they are a great tires.
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
      12-16-2018, 03:37 PM   #16
rich8566
rich8566's Avatar
Drives: M2 + Z-4
Here's the exact track setup I used on my '14 235i: 17" Kosei K4R 17x8 et42 on all four corners with 245/40/17 Hankook RS3s.
2addicts
