Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Losing tire pressure
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      06-30-2008, 10:59 AM   #1
xpcgamer
xpcgamer's Avatar
Drives: 99 Touring
At around 8k miles I began to notice my tires where getting cupped. I have non zsp 328i and running the bridgestone RFT. When I checked my tire pressures where around 28 PSi. I rotate and rebalance and now at 10k I check again and they are around 28 to 30PSI. Is this normal and why did'nt the TPM set off my light?
99 528IT,Sport 5Sp,Xenon,Nav,Rear shades
      06-30-2008, 05:31 PM   #2
ModBargains.com
Drives: JB E92 335i
Check your driver's side door. When you open it, on the left side of the driver's side seat, there should be some specifications. The recommended PSI with the stock wheels are there. I believe typically the TPMS goes off when the PSI is 5PSI or more too low.
      06-30-2008, 05:44 PM   #3
Beer Goggles
Drives: 2007 335i E92, 6MT, Sport
And all tires loose pressure over time. They also change with temp. You have to set pressure of tires when they are cold.
      06-30-2008, 07:04 PM   #4
ModBargains.com
Drives: JB E92 335i
Oh right, that is correct, thanks for adding that Nice one
      06-30-2008, 07:42 PM   #5
xpcgamer
xpcgamer's Avatar
Drives: 99 Touring
I know. I check them in the morning or after the car has been sitting all day and I go to leave the office. Thing is my Pathfinder's light will go off after 1 tire drops by a few pounds. The dealer said the TPMS wont be triggered if all the tires loose air slowly. Whats that about? I could be driving on a long trip and end up with 20PSI in my tires and I get no warning?
      06-30-2008, 08:22 PM   #6
TK-421
Registered Sex Offender
Drives: E46 M3 | 1JZ S13
i have nitrogen in my tires. the pressure stays constant longer and i get free refills from where i got it (olin mott tires)
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
      06-30-2008, 08:42 PM   #7
xpcgamer
xpcgamer's Avatar
Drives: 99 Touring
Does it ride smoother and less noisey?
      06-30-2008, 11:05 PM   #8
homydevil
homydevil's Avatar
Drives: 328i cabriolet
The warning goes off in case of differential in rotating speeds of tires, if all lose air at the same rate , the system cant analize which tire is rotating less
You must have slow leak or something, but first try to inflate the tires according to the scale and load on the car and see where that takes you
      07-01-2008, 01:59 PM   #9
xpcgamer
xpcgamer's Avatar
Drives: 99 Touring
Well that stinks? Why have a monitor TPM sensor in each wheel? If that was the case wouldn't it just use the ABS sensors? I'll keep an eye on 4. Damn tires seem to wear out pretty quick to. I am hoping they last me to 3/9 when the lease is up. I hope I dont run into this when I lease the next one!
