08-29-2018, 09:03 AM | #1 |
93
Rep 244
how is the HK on the m2c?
Anyone who has already taken delivery....can you tell me if there have been any changes/improvements to the HK sound system? Seeing mixed reviews on the system in the 16/17 models.
Not gonna lie one of my favorite things about my 3 series right now is the HK Logic 7 system and I'm hoping the HK on the m2c won't disspoint me (or at least not too much) |
08-29-2018, 09:09 AM | #2 | |
205
Rep 189
08-29-2018, 09:18 AM | #3 |
4399
Rep 2,856
Drives: BMW M2 CSL Turbomeister
It will be similar... It is not brilliant.
I am getting an upgraded kit similar to Bavsound installed in mine over the winter. MR |
08-29-2018, 09:18 AM | #4 | |
142
Rep 183
This all assumes the M2C system is the same as the 17+, and I haven't seen anything saying that's not the case. |
08-29-2018, 10:25 AM | #5 |
Rep 19
I am coming from my M3 with Logic 7, after a week with the M2C, I will say the sound is just 'meh'. It is not a huge disappointment from the Logic 7, but not having the EQ to dial it in to my tastes is probably the reason it does not sound as good.
08-29-2018, 01:24 PM | #6 | |
93
Rep 244
Thanks! Last edited by dont_Mistak3; 08-30-2018 at 07:07 AM.. |
08-29-2018, 09:40 PM | #8 |
365
Rep 239
Drives: 2021 M2C
08-30-2018, 12:46 AM | #9 |
568
Rep 276
///M Houbi1655.00 |
08-30-2018, 03:07 AM | #11 |
377
Rep 596
A car with reduced sound insulation and a loud exhaust is never going to be the ideal candidate for a sound system. The HK is pretty good in the 235 and its the same system in a noisier car. I personally wouldn't want to spend any money putting an aftermarket system in the likes of the M2C when its not exactly optimised for it.
08-30-2018, 05:04 AM | #13 |
5940
Rep 3,291
The HK in my 340, which I hadn't heard in so long, has a massive spike around 200Hz that throws everything off, especially the sound of male vocalists. The system sounds OK after setting the 200Hz slider down about 4 clicks on the EQ. I'm dreading hearing the system in the M2C without an EQ to tame the spike.
08-30-2018, 08:39 AM | #14 |
568
Rep 276
08-30-2018, 10:38 AM | #15 | |
2865
Rep 3,842
Use a plastic trim tool to pop out the center grill. Unscrew the speaker. Lift the speaker up and disconnect it. Push the wire out of the way. Reinstall the speaker. Last edited by AlpsRider; 08-30-2018 at 03:44 PM.. |
08-30-2018, 10:43 AM | #16 | |
568
Rep 276
slowbrick48.00 |
08-30-2018, 10:45 AM | #17 |
2865
Rep 3,842
08-30-2018, 03:33 PM | #18 | |
568
Rep 276
Nkc1600.50 |
08-30-2018, 08:32 PM | #19 |
1042
Rep 1,345
Focal? I added Focal drivers to my 17 and they were a big improvement. I was very surprised swapping out the under seat subwoofers. I also disconnected the center.
