BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    New Release! Upgrade for the BMW M5 (F90) - KW Variant 4 with 3-way dampers
      08-23-2018, 04:23 PM   #1
Dan@AutoTalent
Dan@AutoTalent's Avatar
Drives: E36 M3
Email or PM me if you have any questions!
Dan@AutoTalent.com
Dynamic driving upgrade for the BMW M5 (F90):
Now Available KW Variant 4 with three-way-dampers!
The coilover suspension, made of aluminum, has a ride height adjustment range of 10 to 30 millimeters on both axles.
The Variant 4, the BMW M5 reacts neutral to load changes and offers a razor-sharp steering response. On poor roads with a wavy asphalt surface, the suspension dampens harmoniously and prevents restless driving. Pitching and rolling movements of the body structure are also significantly reduced.
KW rely on similar damper technology as the original equipment of the BMW M4 GTS, where we also once worked together with BMW,” continues Johannes Wacker. "We also develop and manufacture suspension components for BMW M's factory customer motorsports such as the M235i Racing or other M special models.” This multi-valve technology also considers the grip level of the tires when changing from road tires to sports tires. Even with maximum lowering and fast driving over bumps or large transverse joints, the wheels react harmoniously thanks to the blow-off characteristics of the TVCLH-A valves utilized in the Variant 4 dampers.
Tags
auto talent, kw f90 m5, kw suspension, kw variant 4
