08-23-2018, 03:02 AM | #1 |
39
Rep 394
Autobahn tyre PSI
I know it's recommended to increase tyre pressures for extended high speed runs. I'm heading Germany over the weekend and there will no doubt be some derestricted autobahn stints, what should I be setting the PSI to on the standard BMW 19 inch wheels?
f87 M2 Competition
f36 435d M Sport e92 335i M Sport |
08-23-2018, 05:50 AM | #2 |
14
Rep 37
I set mine to the maximum pressure as set on the B-Pillar - I was carrying equipment in the back so the car was reasonably heavy. Unfortunately the Autobahns were very busy so occasional blats to 120 or so was all I could do whilst staying safe. Very impressive how stable the car felt at high speed. Watch out for foreign registered cars pulling out in front of you...
DarrenL_007208.50 |
08-23-2018, 06:48 AM | #3 |
2856
Rep 5,608
HI
As above i go with the B pillar settings. while you will be going fast, i doubt you will get hour after hour at over 120mph etc as the traffic wont allow normally...unless at night and the bahns are pretty dark at night and take a bit of getting use to at high speeds. Last edited by mikeoz; 08-23-2018 at 07:07 AM.. |
08-23-2018, 06:55 AM | #4 |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Is that right?
I've heard that you should increase the pressure for increased loads, but not for high speed running.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
08-23-2018, 06:59 AM | #5 |
39
Rep 394
Apparently so. Something to do with the number of revolutions the tyres are doing at speed so the shape of the tyre changes, therefore higher pressure keeps more of the rubber on the road.
I think that's right lol!
f87 M2 Competition
08-23-2018, 08:45 AM | #7 |
6659
Rep 15,858
Yes, it is appropriate to increase pressure for higher speeds. Many tyre pressure placards, years back, gave pressure recommendations for normal and high speed use.
It is not only higher loads which require higher pressure, in fact at the top end of a tyre's load/speed rating, load capacity decreases as speed increases. Here's a good explanation, plus some charts giving examples. https://www.tyreleader.co.uk/tyres-a...ssure-to-speed |
08-23-2018, 12:07 PM | #8 | |
6733
Rep 20,651
Wills28656.00 |
08-23-2018, 12:23 PM | #9 | |
1616
Rep 2,274
Enjoy your trip!
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
08-23-2018, 04:55 PM | #10 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
I took mine to Munich in Feb this year, I just ran them at the normal pressures I do here. On the unrestricted Autobahns, you’ll only be doing fast stings in short bursts. The rest of the time you’ll be doing speeds that you’d do here. I shouldn’t over complicate things as you’ll have to remember to reduce the pressures too....
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
08-24-2018, 03:20 AM | #12 |
Barge driver
8656
Rep 12,425
The pressure charts show you what cold pressure you should put the tyres to those figures are valid and have been tested up to the Vmax of the car.
I wouldn't go messing around picking a number out of thin air....
730d/Z4C
08-24-2018, 03:47 AM | #13 | |
8567
Rep 19,982
ukbeemerboy462.00 |
08-24-2018, 06:42 AM | #14 | |
6659
Rep 15,858
What we do know, most tyre failures not due to penetration from objects as we drive, (delamination, blowouts, fatigue) are due to running low pressure. Triggered by overload, (excess heat), not setting for the weight carried and/or speed. Saying that, most BMW models run pressures close to the pressure required for the maximum load rating (L.I.). Many of us run pressures between the normal and full load pressure recommendation anyway, so not so critical for adding pressure. Any doubt, run the higher recommended figure, for sustained high speed. |
08-28-2018, 11:45 AM | #16 |
283
Rep 797
Dutch in my experience.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
08-28-2018, 12:00 PM | #17 |
39
Rep 394
Just to update, made it to Koblenz and back with no issues. Tyre pressures were set cold to 40 psi for the whole trip so I'm guessing that would be about right.
Had a good run through Germany, good progress made on the Autobahns with several stints at the 155mph limiter. Hit the limiter with relative ease with the GPS app reading 154mph. Did 4 laps on the Nurburgring too. As capable the 435d is, we all know that it isn't built for the track, but it performed very well considering. It's on the Eibach springs which no doubt helped matters. I was careful not to cook the brakes but I'm certain I was comfortably under 10 mins. A friend of mine followed in his track car with GoPro set up on his cage, so will share the video if anyone is interested. Lots of M3s and M4s around tempting the upgrade lol!
f87 M2 Competition
