08-22-2018, 08:59 AM | #1 |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Seized/sheared brake bleed nipples- anyone else?
I was due to get the Alcon brakes taken off my old 335d this week, and the original blue Brembo MSport brakes re-fitted. There was an issue with both calipers however, and all 4 nipples are seized and one has already sheared off.
I had a similar issue with the rears, and one was replaced under warranty, and I don't think this is an uncommon issue. Anybody else had this? Also, for anyone who has had to deal with this but not under warranty, can you let me know what you did, in particular if there was a company you dealt with that refurbished and repaired them. There's a few for sale on ebay, but reluctant to buy used ones with same issues! Thanks,
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
08-22-2018, 12:07 PM | #2 |
1099
Rep 2,598
Yes, quite common.
I often buy & sell these calipers, and have had two incidents with siezed nipples. Not helpful now, but would have been a good idea to loosen them off before storeage! Brake Caliper Refurbs on FB are the best in the business to fix these for you. |
Tengocity8567.00 |
08-22-2018, 12:09 PM | #3 | |
8567
Rep 19,982
This company? http://www.brakecaliperrefurbs.co.uk/ I'd found them earlier and was going to get in touch with them. Ballpark price?
08-22-2018, 01:05 PM | #4 | |
1099
Rep 2,598
I think he charges £35 per nipple, plus return postage costs. |
08-22-2018, 03:51 PM | #5 |
85
Rep 105
It could be work buying something like Rusteeze and if you're not in a rush then spray some on and leave it for a few days. This should/could work and save you a lot of money.
Its probably worth trying it for somewhere around a tenner. Because the nipple and the calliper are not the same material the oxidise and corrode together and they can be horrible to get off. Fingers crossed it all works out for you.... |
08-22-2018, 05:00 PM | #6 |
281
Rep 1,524
I have found Plus Gas a very effective release agent. https://www.eurocarparts.com/ecp/p/c...4741&0&cc5_857
08-25-2018, 05:55 AM | #7 | |
86
Rep 149
I've been experiencing a rubbing sound recently from my driver's rear wheel area and I'm wondering if it might be the same issue. The car's already booked for the 14th of Sept anyway. |
08-25-2018, 06:07 AM | #8 | ||
8567
Rep 19,982
08-28-2018, 02:57 PM | #9 |
86
Rep 149
09-28-2018, 11:45 AM | #10 |
64
Rep 397
I put my f30 in for an MOT and brake fluid change today and turns out one of the nipples are seized so they are checking the rest and asking bmw to cover it! I'm 1 day out of warranty just waiting to hear the outcome
09-29-2018, 03:16 AM | #11 |
73
Rep 187
Drives: 330d f31 msport
just read all this with interest as ive had bikes for years and always changed the crap oe bleed nipples for stainless !! and never encountered further problems .
anyone know the size and thread size / pitch for m sport blue caliper fitting ??? sounds like it may be a prudent bit of maintenance ! |
09-29-2018, 03:18 AM | #12 | |
8567
Rep 19,982
09-29-2018, 05:31 AM | #13 |
1099
Rep 2,598
09-29-2018, 05:31 AM | #14 | |
64
Rep 397
Who did you use mate? As I stated above put car in for brake fluid change and when I contacted them this morning they said the car requires two calipers and they have put in a good will request to bmw as the warranty expired on Thursday just waiting to hear the outcome but if I'm having to foot the bill I would rather get my calipers repaired than spend £1200 |
09-29-2018, 05:34 AM | #15 | |||
8567
Rep 19,982
These guys: https://www.bcs-automotive.co.uk/bra...refurbishment/ Really helpful on the phone, easy to deal with, quick turnaround and a good price.
09-29-2018, 07:18 AM | #17 |
Fool
1857
Rep 3,542
Mine had the brake fluid done a couple of days ago and I meant to ask how the nipples were but I had no notes on the worksheet about them or any replacement callipers so I'm assuming it all went fine...
09-29-2018, 09:26 AM | #18 |
901
Rep 1,801
Likewise. I can only assume mine went fine too as you'd expect them to make a big thing about it if they sheared off.
09-29-2018, 11:18 AM | #19 |
130
Rep 358
There is preventive maintenance.
When the car is newish most know it's a good idea to remove the wheels and apply copper slip grease or similar to the wheel hub centres ( but NOT to the wheel mounting faces or the bolts!). At the same time you can apply grease around the protruding threads of the bleed nipples.It can prevent corrosion if it's caused by moisture seeping down the threads. I believe it's helped for me in the past. |
