BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Brake fluid on new F90 M5
      08-17-2018, 12:21 PM   #1
tdlondon
Drives: 2019 X7 and 2020 X3 M40i
1985 BMW M635csi  [0.00]
2018 BMW M5  [0.00]
Good day folks! Just took delivery of my new M5 and I'm anxious to go through the break in miles and see what that thing is capable of.
Question: do you guys know what type of brake fluid comes stock with this car? If I'd want to use a 660 fluid, is it a straightforward process to bleed the system on this car or does it require the shop computer to open valves etc?
Thanks for your input
Thomaz
      10-08-2018, 08:20 PM   #2
tdlondon
2018 BMW M5  [0.00]
Bumping up: has someone done a brake fluid change on the F90? Is it straightforward or does one need to hook a computer up while doing this, in other words, only the dealer can do that? Thanks
      07-09-2019, 02:29 AM   #3
mayanm
Drives: F90 M5 Comp
I had the dealer do this and it was a quick job for them. Successfully completed a HPDE at Laguna Seca without any brake fade. 660 is the way to go, should be standard fluid on these cars!
      09-17-2019, 08:59 PM   #4
shawnhayes
1830
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
Have replaced mine with Castrol SRF. It's a straightforward standard Brembo gravity bleed in the front. The ABS might not vent without the dealer tool, but the wheel calipers bleed directly from the reservoir just fine.
Shawn
