08-15-2018, 07:30 AM | #1 |
101
Rep 322
Down on Power??
I have a 340i with MPPSK.
Thought I would take it to my local Dyno to see what power figures I have. They use a "Mustang" dyno which from research seems good and accurate. The power @ wheels were only 294hp. Obviously a bit disappointed and expected much higher. Looking at the DMS thread, Chris-c got a 372.2hp on his MPPSK car (Prior to DMS map). Assuming 12% losses, my 294 hp would translate to 334hp @ fly. quite a way off the 372 achieved by Chris. I did wonder if the engine map from the MPPSK may not have been correctly applied or wiped after recent warranty work (Car is now out of warranty). Checking through various posts, it seems the in car power figures should be reading 370-400. After several attempts, the best I could achieve was around 365 (Assuming each square is 25hp) I've spoken to my local dealer and they can check the ECU but will be charge a diagnostic fee of around £85 if everything is found to be OK. £0 if the MPPSK tune has not been applied and needs to be re-installed. I want to be extra sure before taking to BMW for obvious cost reasons. Can anyone confirm if my figures seem correct? Do they appear more in line with a non MPPSK car? |
08-15-2018, 07:45 AM | #3 |
1388
Rep 2,127
To be honest, you cant compare your figures to Chris-c figures as they were done on different dynos.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
08-15-2018, 08:17 AM | #4 |
101
Rep 322
08-15-2018, 08:22 AM | #5 |
3489
Rep 9,709
As above, it's not easy to compare one dyno type with another. 294 at the wheels seems a little low, but could be fine on a Mustang. Dynodynamics have MPPSK around the 300-310 whp mark IIRC. In fact look for the Surrey rolling road thread to see the full tables.
Edit* lowered the WHP numbers for MPPSK after consulting the spreadsheet masters file. MarkG_M3CP There is a dyno finder on the dynodynamics site which will get you to the more common type used. Are you far from Farnborough? Surrey rolling road has dyno'd many MPPSK 340i for comparison. |
08-15-2018, 08:31 AM | #6 | |
101
Rep 322
Would consider a trip down for a rolling road day and meet some people, but a bit far to just go for a power run. (Live just south of Coventry) |
08-15-2018, 08:44 AM | #8 |
3489
Rep 9,709
MarkG_M3CP
Here you go guys, the compiled results... Ranked in order of gain: Attachment 1687795 Attachment 1687796 For interest, an overlay of the 30d engines: Red = DMS remap Blue = DMS remap Green = Bluespark Pink = DTUK Attachment 1687797 |
08-15-2018, 08:53 AM | #9 |
101
Rep 322
Found it now, but when searching it was on page 2 of the results. Seems the mobile app is better at searching.
@nisfan, Thanks for the results. Seems like both the 340 and 440i both with MPPSK got around 300 hp @ wheels. So difference there could be dyno differences as its soo small. So seems car is good and power as expected. Thanks for the help. |
08-15-2018, 09:10 AM | #10 |
629
Rep 1,470
Bloody hell those DMS remaps exploit some power and torque don't they? Has anyone had any issues with reliability on the 30d pushing so much power out?
08-15-2018, 09:27 AM | #11 |
901
Rep 1,801
Seeing SRR showing 300-305whp means your 294 is 2% lower than SRR's reading.
Do you not think that is within an acceptable margin of error? I'm taking my figures with a pinch of salt. The gains are impressive and the car has been transformed but I'm still not sure if I believe 444bhp calculated. |
08-15-2018, 09:34 AM | #12 | |
101
Rep 322
Yes, seeing as 2 other b58's with MPPSK got around 300hp @ wheels, I am happy to go with my 294. Just thought it best to double check as i've seen high figures stated for the mppsk and mine was much lower than expected. |
08-15-2018, 01:55 PM | #14 | |
1669
Rep 3,967
MPPSK is supposed to be 355bhp? not 370+ |
08-15-2018, 02:39 PM | #16 |
1669
Rep 3,967
08-15-2018, 02:55 PM | #17 |
901
Rep 1,801
Yup. If you check the thread in the B58 section about B58's it shows 355bhp for the MPPSK. When I got mine I took a photo of the details of the kit in the showroom and it clearly showed 360bhp.
Either way the MPPSK is still a very decent improvement. The power is noticeable as I went from a non mppsk to a mppsk back to a non mppsk car and you could certainly feel the difference. Then the sound. Holy hell the sound makes the difference! |
08-16-2018, 04:37 AM | #20 | |
6416
Rep 8,499
I always use BP Ultimate and Millers Oils additive, every tank, on the assumption that this will keep the engine internals as clean as possible as well as benefitting from the Cetane boost. The only dip in fuel efficiency (~3mpg) was when BMW applied a software update without my permission (the DMS map had to be re-applied) presumably as an 'under the radar' diesel-gate emissions adjustment.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
