2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum N63TU Abnormally high IAT
      08-14-2018, 07:13 AM   #1
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Hi all,
Running 2014 550i N63TU. Bootmod3 Stage 2 tune, catless stock DP, M5 comp exhaust. New Bosch OEM plugs gapped to .021.
Engine has been pulling power due on full throttle due to high IAT. Getting a bit of knock also.
On most runs peak IAT is 156-160F with 93F ambient temp.
I ran it both with ARM intake and OEM intake with similar results.
Anyone have ideas what could be causing high IAT? No codes.
Next step is probably spraying meth but if there is an issue I'd like to correct it.
Pic of car and tab-delimited log (for excel import since i can't upload a .csv) attached.
Thanks,
Ian
2019 M5C Matte MBB / Tartufo
      08-14-2018, 02:59 PM   #2
V8LIFE
26
Drives: 650i
You will get more help if you post it on bm3’s Facebook group
      08-15-2018, 07:07 AM   #3
135i_vs_
135i_vs_'s Avatar
Drives: M5, 135i, 335d, F10 550xi
If the IAT is only climbing when you are idling then it is ok.
If the IAT does not get within 10-15F of ambient when you are WOT, then you probably should get a new IAT sensor (I think it is part of the MAF on these cars).
      08-19-2018, 01:20 AM   #4
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
If youre getting knock, you might want to try running an octane booster.
5post
