08-13-2018, 03:34 PM | #1 |
217
Rep 519
P3 Cars Multi Gauge in Vent
Get the Oil temperature of your M235 that the stock dash does not have!! Specifically designed to support the M135i, and M235i and F87 M2 platform, also supports 116i, 118i, 128i, 228i P3 Digital gauges provide the highest level of OEM integration and color match offering more features than any other gauges in their segment. Starting at a price competitive to single feature old-school needle gauges, they offer unmatched feature to price ratio. All gauge models include an on-the-fly configuration menu for setting units (BAR/PSI for boost, and C/F MPH/KPH for multi-gauge values), as well as feature options, and ambient calibration. See www.p3cars.com/install for more details. P3 Multi-Gauge Boost and Vacuum from OBD2 port Plug and Play install - just plug into your obd2 port and install into dash! Optional analog sensor for reading boost on tuned/big turbo cars. OBD2 Data for Oil Temp, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Angle, Speed, RPM with Shift-light, Battery voltage and more! Optional Auto-Dim or Manual Dimmer Code Read/Clear 2 x universal 0-5v linear analog inputs Includes Digital Display, Custom OBD2 Wire Harness, Control Box
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
