2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB ZF8 ATF CHANGE - Just Shy of 50K
      08-08-2018, 04:06 PM   #1
123Britt
Drives: 15 M235i AT
The 5L of Fluid I drained out does not look clean in the glass compare and the (4) magnets had a creamy smear of captured metallic particles.
Using the Foxwell Reader to measure AT Temps, ZF ATF Kit with Lifeguard 8 Fluid.
*The fluid dripping from the transmission looks clean and light green &
makes me believe that the L8 is the OEM fluid.
*Simple job & followed the FCPEuro instructional video along with the ZF
Company video.
*The ZF pan was identical to the BMW pan. OEM
*I will look to do this service again at 100k.
*Based on the color and metallic captured -- I would recommend this for
sure before 60k.
Cheers
Appreciate 2
      08-09-2018, 10:11 AM   #2
amw896
amw896's Avatar
583
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
nice work! Obviously lifetime fluid is a joke. The should specify, lifetime (of a lease) fluid.
      08-09-2018, 02:37 PM   #3
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
It's not a joke, if their objective is to get you into a new every couple of years.
      08-09-2018, 04:45 PM   #4
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
Now we need a post from a member with a manual transmission fluid change at that same interval or less. I'm only at 17K. I can't do it.
      08-09-2018, 05:01 PM   #5
Black2
Australia
Drives: 2015 m235i
Mind linking us to the video you used to diy this?
      08-09-2018, 05:51 PM   #6
123Britt
Drives: 15 M235i AT
Zf Video - Not Exact But Close
The 3 Series DIY section has several links
10nm Bolt torque (13) Total (I used a dial type torque wrench)
Star Pattern starting at corner and moving clockwise
34nm Torque on fill bolt
Pan drain was already installed - I tightened one additional click
Temp Range is listed on Green sticker on the side of the pan
      08-09-2018, 08:12 PM   #7
amw896
amw896's Avatar
583
I did mine at 40k km. Shop said the fluids integrity was still good but it was pretty dark. Shifting engagement was improved a bit though.
Tpeterson156.50
      08-10-2018, 03:28 AM   #8
delvec03
90
Drives: 228i Sport/ DSB
can also verify that shifting quality after 6mt fluid swap is noticeably better. did the swap around 50k. installed magnetic drain plugs because reasons.
Tpeterson156.50
      08-10-2018, 06:26 PM   #9
3rdcoast228i
225
Drives: 2016 228i Msport
Good job, thanks for the post.
      08-11-2018, 01:11 PM   #10
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I did mine at 70k miles . 6MT. I used RedLine fluid and did a Blackstone report too. Search for it.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
Tpeterson156.50
      08-11-2018, 01:39 PM   #11
Tpeterson
Tpeterson's Avatar
Thanks. I''ll look for it.
      08-11-2018, 02:04 PM   #12
Tpeterson
Tpeterson's Avatar
I see you used Red Line D4-ATF. The several times I checked on their website,including an email from their tech support, they recommended D6-ATF .I should have the same Getrag transmission that your car has. Mine's a 2015 228i.Why did you choose D4?
      08-11-2018, 10:32 PM   #13
SteveInfante
I used D4 because that what Chad Morehead from MSW uses in all his race cars that he builds for the SPEC E46 series. It's noticeably smoother when shifting.
Tpeterson156.50
      08-12-2018, 01:01 PM   #14
Tpeterson
Tpeterson's Avatar
Red Line told me D6 most closely meets the BMW OE fluid specs ,meaning it's thin. Shifts probably wouln't be an smoother with it,then.
      08-12-2018, 03:04 PM   #15
SteveInfante
I do plan on testing the RL fluid when I change it out to compare.
Tpeterson156.50
      08-12-2018, 06:19 PM   #16
123Britt
Drives: 15 M235i AT
D4 Viscosity
Wonder how the D4 in winter temps will affect your shifting with the thicker fluid.
      08-13-2018, 07:55 AM   #17
SteveInfante
I have about 23k more miles and I will let you know. Late December through mid March are the coldest months here in Sunny South Carolina. I always let things warm up before I have fun so I'm not too concerned about that really.
2addicts
