08-08-2018, 12:10 PM | #1 |
80
Rep 694
EGR Campaign
https://www.press.bmwgroup.com/globa...nical-campaign
What’s everyones thoughts on this ? My cars currently in as a good will (£150 contribution from myself) to replace and inquired about this to them and bmw uk and both are clueless lol |
08-08-2018, 05:10 PM | #2 | |
310
Rep 1,338
Drives: 2014 F30 320D X-Drive
I would expect this to affect earlier model rather than model in between production cycle
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
08-08-2018, 05:28 PM | #3 |
3719
Rep 8,636
for the 2.0 not the 3.0
08-09-2018, 01:14 AM | #5 |
714
Rep 1,241
Strange that the website doesn't cover this on its recall page https://www.bmw.co.uk/landingpages/bmw-vehicle-recalls
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive |
08-09-2018, 05:17 AM | #7 |
3105
Rep 7,032
Drives: 335xd Msport +
Had my egr cooler changed under warranty as it cracked and was leaking coolant along with cleaning
Think I should be safe then?
08-09-2018, 03:28 PM | #11 |
310
Rep 1,338
read it properly it also 6 cylinder!
are you getting bullied by x35i and x40i drivers then feeling like passing it on to 4 cylinder owners?
08-09-2018, 04:32 PM | #12 | |
3719
Rep 8,636
6cyl is "(production from July 2012 until June 2015)" Would you like a plate? |
08-10-2018, 02:40 AM | #13 |
518
Rep 944
Pleased to see they are instigating action.
The fault could be down to poor manufacture (rather than an inherent flaw in the design) of the original part so, even if no redesign of the EGR has occurred, replacement could overcome the potential for the fault to occur if the quality control has been improved. |
08-10-2018, 02:59 AM | #14 | |
6659
Rep 15,858
VW's fiasco with trying to sort NOx with modified software, is reported to cause EGR component failure in many cars. Indicates exhaust gas flow rates are pretty sensitive to control, across a breadth of use. I suspect EGR flow rates may be too high in some situations. Some users driving will have more gunk building up, other driver's use will generate more heat. Both extremes can cause issues, combine the two and in some examples there is the recipe for the extreme reaction, fire. |
08-10-2018, 04:09 AM | #15 |
13347
Rep 7,484
With time an EGR can only kill an engine. The only way is to keep an eye on it. Even if you do motorway runs it might stick. Carbon will build up at some point and mess up the intake manifold. So true ownership costs include cleaning those components. An EGR leak can devastate in terms of a fire breaking out. People harp on about the environment... but would you really care if you missed an EGR fault... you were out of warranty and looking at the cost of a new engine? EGR has good intentions but the whole system is poor design. It is a shame that an entire engine warranty can be voided by BMW by removing or blanking the EGR.
I said it in another thread but BMW lied about 19 fires to the DVSA. They were caught out but kept on lying until eventually they were asked to address some of the problems. |
08-10-2018, 07:04 AM | #16 | |
6659
Rep 15,858
Problem as I see it, as diesel emission systems age we have in reality higher costs, both for proper maintenance and keeping emissions low. MOT is still really playing with emission levels, "the elephant is in the room". Proper testing is really required (different rpms and load levels) and would highlight the real costs of running and maintaining higher mileage diesel. |
11-11-2018, 03:59 AM | #17 |
Rep 44
Mine's a 2014 N47 F31....
I recently insisted my BMW dealership check for EGR Cooler failure whilst my car was in for service after coolant went low twice with no warning and with no apparent escape! Coolant pressure test was ok; technician diagnosed egr Cooler failure & the dealership are raising a claim case with BMW even though my build doesn't currently appear on the UK BMW EGR Cooler recall technical campaign! More info here: https://www.bmw.co.uk/landingpages/b...e-recalls#gref And here: https://www.bmwblog.com/2018/10/23/b...lion-vehicles/ My build is a 2014 F31 320D N47 efficientDynamics auto My advice; if you're coolant goes low for no apparent reason; take it to a dealership & demand a test regardless of whether your build is on a recall list or not, & fight your corner before anything catastrophic & costly occurs! BMW press release: https://www.press.bmwgroup.com/globa...86151EN/417072 |
11-11-2018, 05:11 AM | #18 | |
3719
Rep 8,636
11-12-2018, 03:55 AM | #19 |
207
Rep 190
I had a drivetrain error last year and after diagnostics at BMW found it to be EGR. Car was 3 months out of warranty. After negotiating the dealership replaced that and whole bunch of other components after a 400£ personal contribution.
In light of recent EGR press release/recall my car qualifies in this program. Should I be speaking to dealer to get my contribution back? |
11-12-2018, 04:16 AM | #20 | |
6420
Rep 8,500
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
11-12-2018, 04:21 AM | #21 | ||
207
Rep 190
Initially just the EGR was replaced but after driving it back I got the same drivetrain error. It went back and forth several times with head office in Munich advising my dealership which components to replace. The total parts bill was apparently 4K but everything was a result of the cracked EGR. |
11-12-2018, 06:51 AM | #22 | |
276
Rep 777
