08-04-2018, 03:43 AM | #1 |
210
Rep 1,252
Battery discharged, start engine.
I've got a warning message about low voltage battery yesterday while driving on the highway, after stopping at home i went to secret menu and showed battery v11.5, and thats very low but not sure why the car says start the engine and i was doing around 60mph when i got it .
Is it a bad IBS or Alternator? Im not sure where is the IBS though if its the only thing needs replacing.
Docrace 6266
08-04-2018, 02:41 PM | #2 |
210
Rep 1,252
After I started inspecting the car. I noticed that the red cap for battery terminal near fuse box is melted and saw smoke coming from the terminal. the plastic on the terminal was melting which explains the bad smell when turning on AC; I was getting since a few weeks ago.
when turning off the car it doesn't happen. I cleaned the contact points with a knife and after that, the car started somehow better and it charged up from 11.1v to 13.2v for few revs in a minute which is weird but it was still smoking.
Docrace 6266
08-05-2018, 05:52 AM | #4 |
210
Rep 1,252
I think the alternator is shorted internally. that causes all this heat.
I'll test on alternator after work. With multimeter as far as my research Test plan: Ill turn ign ON Probe1 red Alternator, probe2 Red jumper terminal Probe1 ground, probe2 alternator case/housing
Docrace 6266
08-07-2018, 09:31 PM | #5 |
8270
Rep 16,125
The alternator should either work or not. A loose wire between the alternator and the battery would explain the heat and the low battery voltage. I don't know how the wiring runs, but since the alternator and the charging post are both under the hood it makes sense that the alternator wiring connects to the charging post, which then connects to the battery. That would seem born out by the heat there. With the car running measure the voltage at the alternator, at the post and at the battery. They should all be the same, roughly 13v. If not there's a bad connection, perhaps even a bad cable somewhere.
08-11-2018, 05:59 AM | #6 | |
210
Rep 1,252
Docrace 6266
11-28-2018, 11:56 PM | #7 |
210
Rep 1,252
Im still getting low battery after 3-4days undriven, yet it starts like new car. and the voltage read by dashboard Ubatt = 14.8 at idle, went to 15.0-15.2 while driving (~2k rpm)
Docrace 6266
11-29-2018, 07:16 AM | #8 |
8270
Rep 16,125
What does the voltage read after sitting a few days before you start it? What you read when the engine is running is the alternator output. If the battery voltage drops to lower than 12v before you start the car the battery needs to be replaced.
12-01-2018, 02:00 PM | #9 | |
210
Rep 1,252
will try to pop the secret menu again tomorrow morning before firing it.
Docrace 6266
Tags |
335i, alternator, battery, dischared, f30, ibs, low battery |
