BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
      06-24-2008, 12:52 PM   #1
emergent
not a poof
emergent's Avatar
Drives: 2013 Monte Carlo Blue X5M
Vorsteiner Rear-Diffuser Installation
I just received my Vorsteiner diffuser today, and I was wondering if anyone had any information on how to install it. I see the 4 screw eyelets, but how is the front held on? I heard something about 3M tape. I'm also assuming I would need to get a jack and jack stands, correct? Any help would be appreciated.
2013 Monte Carlo Blue X5M | Active Autowerkes Software | Vorsteiner Vented Race Hood (soon) | K&N Filters
      06-24-2008, 01:10 PM   #2
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
You don't need to jack the car up to install it. All you need is 3M tape and it helps a lot if you can get that 3M tape adhesion promoter because it really makes the tape stick so much better. Oh yeah, make sure you use a wax remover before you put the tape on as well. It's easy enough to install it yourself, but if you can find a good body/customization shop, they probably have the packets of the adhesion promoter sitting around and it would take them all of 10 minutes to install the diffuser for you without making rookie errors. They shouldn't charge you very much at all. Some people don't use the good tape, adhesion promoter, or don't remove the wax and wonder why the tape doesn't work well.
I like the description in the link I provided:
Salesman Note: A question I often get asked is: "Do I really need 06396 Adhesion Promotor for the attachment tape to stick?". Answer: Yes and No. No, if you don't care if it falls off after a period of time. Yes, if you don't want to worry about the tape turning loose. The tape turning loose is not the real problem. It's the fact that you're taking a chance of loosing or destroying a high priced molding or emblem. Some moldings may cost as much as $200.00. Sometimes cutting costs up front isn't economical in the long run.
      06-24-2008, 03:28 PM   #3
SV Concepts III
375
Drives: BMW Duh
Yep, in addition, there are several bolts underneath the car that will attach the diffuser to the vehicle.
      06-24-2008, 05:13 PM   #4
Ryan@IND
BimmerPost Supporting Vendor
Ryan@IND's Avatar
Drives: ACR
+1 on the 3M. Those hold up so well, through the chicago winters and the "Floods of the Midwest".
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      06-27-2008, 10:48 AM   #5
ersin
ersin's Avatar
Drives: 17 YMB F80 M3
How about some before and after pics and during installation? Is it painted yet?
2017 F80 YMB.
      06-27-2008, 11:35 AM   #6
LittleRocket
LittleRocket's Avatar
Drives: AW E92 M3
Its Carbon Fiber it doesn't need to be painted unless you wanted to color match your car.
      06-30-2008, 01:00 AM   #7
gadget
gadget's Avatar
Drives: 09 e92///M SSII DCT
      06-30-2008, 06:22 PM   #8
Nate@IND
Nate@IND's Avatar
2866
Drives: BMW
Originally Posted by gadget View Post
Eisenmann + Vorsteiner =
Some booty shots Eisenmann Race Performance with 4x83mm tips and Vorsteiner Rear diffuser.
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      07-01-2008, 10:54 AM   #9
JEllis
JEllis's Avatar
531
Drives: E36 M3, E92 M3
Its a sexy piece
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      07-19-2008, 01:08 AM   #10
1ne
1ne's Avatar
26
Drives: '08 E92 M3 JZB 6MT
If in the future I want to remove this, will the 3M tape damage the paint? What would be the best way to remove the 3M tape? Thanks
      07-20-2008, 11:54 AM   #11
SV Concepts III
375
Drives: BMW Duh
Not at all, the 3M tape is designed to be removed. You can use floss and a heat gun to heat up the paint and floss in between the paint and 3M tape. If there is any residue, Goo Gone will do the trick.
      07-20-2008, 11:59 AM   #12
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
It can be removed without damage. The best way to remove 3M tape is an eraser pad attachment, that's what bodyshops use.
      07-20-2008, 12:25 PM   #13
1ne
1ne's Avatar
26
Thanks Nick and badfish for the info
m3post
