07-24-2018, 01:24 AM | #1 |
13347
Rep 7,484
Thinkware dash cam owners...
What is the maximum parking mode you have been able to achieve without increased battery discharge?
What is your voltage cut off set to? Thanks |
07-24-2018, 03:51 AM | #2 |
6422
Rep 8,501
I have the voltage set to the minimum, which I think is 11.2V. I'm away on hols at the mo so can't check.
I haven't had any parking incidents so it's hard to tell how long that function operates for, however, I also have motion detection activated and that seems to work for several days if the car is left parked for a while.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
Soul_Glo13347.00 |
07-24-2018, 07:25 AM | #3 |
53
Rep 204
I've got mine set to 12.1/2 I think and I haven't had any issues with it cutting out or any discharge notices on the idrive.
The battery seems to hold around 12.4 ish when reviewing the videos as it shows the voltage on the recording |
Soul_Glo13347.00 |
07-24-2018, 08:14 AM | #4 | |
13347
Rep 7,484
12, 24 or 48? |
07-24-2018, 08:16 AM | #5 |
53
Rep 204
12 I think.
But I'm not 100% on how that setting affects things I need to read the manual again as I did have it in 6 before and I never noticed that it cut out after 6 hrs! |
07-24-2018, 09:43 AM | #6 |
470
Rep 786
Drives: 2018 F80 M3 CP YMB
Mine is set for 12 hours (I have front and rear cam) - iirc setting it any higher will cause a battery drain alert
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
