Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - NY / NJ / CT / PA > Hey guys
      07-22-2018, 10:17 PM   #1
SPEEDRACER/n54
SPEEDRACER/n54's Avatar
Drives: 2009 BMW 335 xdrive
Hey guys
I have 2009 bmw 335i xdrive I keep getting code 2c7e and 2c2b for my 02 sensors,I replaced all 4 02 sensors with factory oxygen sensors n still persist if really like some inputs thanks
Sp
      07-23-2018, 05:55 AM   #2
Rob09msport
Drives: 09 335 msport
Do you have any mods ?
      07-23-2018, 07:36 AM   #3
SPEEDRACER/n54
Yea I do
Sp
      07-24-2018, 11:42 AM   #4
Moce72
14
Drives: 2011 335i xdrive
Could be in the wrong banks, I had the same problem when I got my cat back from a hack mechanic, I swapped them and problem solved
      07-25-2018, 05:56 AM   #5
Rob09msport
You need to list your mods and mileage and then we can give much better response
      07-25-2018, 09:28 AM   #6
SPEEDRACER/n54
Car has 61k miles on it really driven,have installed,mishimoto intercooler,and oil catch can,vrsf charge pipe with tial bov,afe dual cone intake,I've replaced coils yesterday and plugs,changed my injectors about 4 months ago I replaced all 4 of my 02 sensor weekend past,retro fitted hard motorsport oil cooler and I'm running all that on mhd stage 1 plus tune
Sp
      07-25-2018, 09:29 AM   #7
SPEEDRACER/n54
I'm 150 percent sure they are not in the Wong banks thts the part thts getting to me
Sp
      07-26-2018, 11:09 AM   #8
Cabdriver
Cabdriver's Avatar
52
Drives: 2009 E90 335i
Try running lambda adoption then clear codes and perform the readiness drive cycle. See what happens then...
      07-27-2018, 07:22 AM   #9
SPEEDRACER/n54
Okay I'll try that thanks
Sp
      07-28-2018, 03:45 PM   #10
SPEEDRACER/n54
Issue still persists
Sp
      08-01-2018, 12:40 PM   #11
Synectic
Drives: 2010 e92 335i mtech
check fuses
      08-02-2018, 04:58 AM   #12
SPEEDRACER/n54
Originally Posted by Synectic View Post
check fuses
Checked all fuses they are all good
Sp
      08-02-2018, 04:59 AM   #13
SPEEDRACER/n54
check fuses
This thing is getting to me been dealing with this issue for over 2 years now
Sp
      08-03-2018, 09:30 AM   #14
Rob09msport
Bad cat ? You have dps ? Try o2 sims or spark plug foulers also could run stage 2 which codes out probes for cat delete
      08-04-2018, 01:52 PM   #15
SPEEDRACER/n54
Can I run stage 2 without Changing the stock downpipe wouldn't tht mess up the car ??
Sp
      08-07-2018, 06:07 PM   #16
Cabdriver
Cabdriver's Avatar
52
Could be your cats....
Personally, I think you should get the issue resolved before jumping to st2 - it is recommended to run catless with 2 or 2+.
If you have bad cats, you could end up causing bigger problems with st2.
Did the car have jb4 previously? Did the car have catless dp previously?
      08-11-2018, 06:50 PM   #17
SPEEDRACER/n54
I'm not sure,and I wasn't going to run stage 2 Withou doing so figured there a reason why it says it's Recomend
Sp
      08-13-2018, 11:36 AM   #18
Rob09msport
If you have fmic you can run stage 2 it is not v recommended to do back to back pulls but wedge himself has stated just log and you will be fine.i am not suggesting to daily stage 2 I mean flash and drive normally , you don't even have do pulls but see if the codes go away if they do you know your cats are bad
      08-15-2018, 07:41 AM   #19
SPEEDRACER/n54
Okay understand I appreciate the input I'll try it out
Sp
      09-06-2018, 09:09 AM   #20
DS3IAM
DS3IAM's Avatar
201
Drives: E90 335 XI
following ..
By any chance did you check the adapters (connectors) to the O2 sensors?
2009 335i xDrive 6MT // Black Sapphire / Cold Weather / M Sport / PDC / Premium Package / Aerodynamic Kit / Anthracite headliner / Keyless Entry / AR Design Catless Downpipe / Style 313 19" Wheels/ OEM Euro Taillights / LUX H8 160
      09-23-2018, 03:38 PM   #21
AWCR1MC
AWCR1MC's Avatar
Drives: 135i
Did you ever figure this out? Having the same problem for the past couple years as well. It's driving me crazy.
~19T turbos upgrade by turbo labs~3.5 Bar Tmap~PR Ignition Kit~VRSF Inlets and outlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~ Turner solid engine and transmission mounts~
      09-24-2018, 10:52 AM   #22
SPEEDRACER/n54
Nah never dis still having the issue bro
Sp
AWCR1MC11.00
