07-18-2018, 10:14 PM | #1 |
Luxury at the redline :)
9105
Rep 7,563
I broke my headlight washer nozzle today trying to remove my bumper, so I decided to do a DIY delete of the whole unit.. Weight reduction..
Anyways, It got me thinking and noticed that M2C doesn't have headlight washers on the front bumper.. As far as I know, all current M2s came with the washers stock.. Am I missing something or is this a pre-production omission? Last edited by Poochie; 07-20-2018 at 01:15 PM.. |
07-18-2018, 10:18 PM | #2 |
10931
Rep 4,551
Drives: 2015 328d xDrive
As far as I can tell they've done away with them and to that I say good riddance. First thing I did when I got my M2 was code them out. The only thing they're good for is making a huge mess.
8
Poochie9104.50 NYC Bimmer259.50 Nahlem1144.00 BAN_M2C4185.00 Alexxxx52.00 VIERsr2623.00 Tag18156.50 TrentMeister2860.00 |
07-18-2018, 10:25 PM | #3 | |
9105
Rep 7,563
Edit: Ok, so from what I just learned; headlight washers are required in Germany for any light on a car with lumen higher than 2000. Xenon is around 3000 lumen, LED is below 2000 lumen. Xenon with dirty lens could possible blind other drivers. So that answers that.. Bye Bye crying headlights.. |
07-18-2018, 10:53 PM | #5 |
10931
Rep 4,551
...so xenons headlights are brighter than LED's?
NYC Bimmer259.50 |
07-18-2018, 11:02 PM | #6 | |
9105
Rep 7,563
They are both capped at 35 watts though.. 22 watts for non-adaptive LEDs or halogen. https://www.autoevolution.com/news/b...led-26530.html |
07-18-2018, 11:18 PM | #7 | |
10931
Rep 4,551
Also kinda makes me wonder how difficult a 55w upgrade would be... |
NYC Bimmer259.50 Kankles1484.50 |
07-19-2018, 03:03 AM | #8 |
258
Rep 162
07-19-2018, 03:54 AM | #9 | |
7334
Rep 7,299
07-19-2018, 07:05 AM | #10 | |
1287
Rep 1,675
And these lil openings below the lights are there still, are they just unoperable then if I have led? |
07-19-2018, 08:04 AM | #11 | ||
9105
Rep 7,563
There are several sources online to confirm this fact. And also the reason BMW are no longer required to supply headlight washers for all LED headlights in the European market confirms that Xenon are "brighter." A definitive answer on headlight brightness LED vs Xenon https://f30.bimmerpost.com/forums/sh....php?t=1230507 https://www.xenonpro.com/led-vs-xeno...ich-are-better https://www.pistonheads.com/gassing/...f=23&t=1520695 https://www.quora.com/Do-I-need-a-he...ight-in-France https://www.micksgarage.com/blog/com...car-headlights Led adaptive headlights vs non adaptive https://f30.bimmerpost.com/forums/sh....php?t=1374141 |
07-19-2018, 03:05 PM | #12 |
2865
Rep 3,842
Even if the maximum lumen output is higher for the Xenons, that doesn't mean that the adaptive LEDs might make better use of distributing their light output. I don't know if there are any specs on that around...
chris7197334.00 |
05-12-2020, 08:53 AM | #13 |
Rep 1
05-12-2020, 09:02 AM | #14 | |||
1717
Rep 1,899
Amongst HID bulbs of the same type there is a huge disparity of lumen output just like with LED bulbs. I'm not convinced the BMW xenon from 2017MY and older M2s are any more bright than the LCI LEDs. They're very close |
05-12-2020, 11:05 AM | #15 |
184
Rep 364
Drives: M2C X5M M4
I had xenon in my old 335d, they were the originals so 120k miles and 12 years they were dim as candles so age has a massive bearing on brightness.
I also have heard that in the uk the legal mot requirements for headlamp washers on xenon was dropped this year |
05-12-2020, 01:01 PM | #16 | |
498
Rep 697
Drives: Alpine White 2020 BMW M2C
Garage List 2017 BMW X6 M [0.00]
2020 BMW M2 Competi ... [0.00] 1993 Mazda RX-7 [0.00] 2006 Mitsubishi Evo ... [0.00] 2005 BMW M3 ZCP [0.00] 2016 Ducati Panigal ... [0.00] |
You said you broke your headlight washer nozzle, but then realized you don't have headlight washers. How did you break something that you don't have? |
05-12-2020, 01:23 PM | #17 | |
6637
Rep 4,145
Drives: '18 M2 6MT
05-12-2020, 01:46 PM | #18 | ||
9105
Rep 7,563
msdss497.50 |
05-12-2020, 06:12 PM | #19 | ||
9105
Rep 7,563
The LCI M2 & Competition both have LEDs, which falls under 2,000 lumens light output, thus, under the mandatory threshold for requiring headlight washers. #TheMoreYouKnow |
msdss497.50 nioh_lbbm21716.50 |
05-12-2020, 10:11 PM | #20 | |
976
Rep 843
If anything, they always seem to break, so in the rare occasion that I push the button to activate it, it doesn't work! |
Poochie9104.50 |
05-13-2020, 05:41 AM | #21 | ||
9105
Rep 7,563
In theory, headlight washers combine with wiper blades, like how some mid-90s, high-end Mercedes used to do, it might of worked better but in practice, washers/squirters are factually useless.. Not to mention, it was pretty surprising but the washer hose lines, pump and squirters weight a good 5lbs, so I was happy to eliminate the system and not just having it siting there, deadheading, while the feature itself was decoded, anyways. #WeightReduction This setup below might of worked better than BMW's headlight washer attempt but are obviously not aesthetically pleasing: |
05-13-2020, 06:13 AM | #22 |
6525
Rep 3,072
Drives: M2 CS, 18 Vantage AMR, 00 WRX
Good riddance to Xenon. Horrible technology. Wait until they fail (and they will spectacularly) and you discover the replacement cost.
